AX2012R2 > D365 Data Upgrade Failed on AdditiveSync
  • AX2012R2 > D365 Data Upgrade Failed on AdditiveSync
    Posted by DSC Communities on May 4, 2020 at 7:38 am
    • Corey Vantilborg
      May 4, 2020 at 7:38 AM
      All,
      Ā  Ā  Ā  I am working on getting our data upgrade to D365 working.Ā  Ā I keep getting stuck on Step 5 of the Pre-Upgrade.Ā  Ā This step is called AdditiveSync and it looks like it does a special database synchronization to have enough of the D365 data schema to start the servers and perform the actual data upgrade.Ā
      Ā  Ā  Ā  Ours fails with a number of errors like the following:
      CREATE FULLTEXT INDEX ON DBO.INVENTTABLE (NAMEALIAS) KEY INDEX I_175RECID WITH CHANGE_TRACKING = Auto;
      —> System.Data.SqlClient.SqlException: ‘I_175RECID’ is not a valid index to enforce a full-text search key. A full-text search key must be a unique, non-nullable, single-column index which is not offline, is not defined on a non-deterministic or imprecise nonpersisted computed column, does not have a filter, and has maximum size of 900 bytes. Choose another index for the full-text key.
      Ā  Ā  Ā  Looking at this error it looks to me like there is an ObjectID issue.Ā  It is trying to create an index with column NameAlias but the index name references RecID.Ā  Ā It fails because NameAlias is not unique(which it is not).Ā  When I look in other D365 environments,Ā  that Index contains only RecID.Ā  Ā Ā
      Ā  Ā  Ā  Ā Has anyone seen this before?Ā  Ā Is this because the Pre-Upgrade checklist I ran in AX2012 didn’t correctly copy ObjectIDs?Ā  Ā I would greatly appreciate any insight anyone could provide.Ā
      Ā  Ā  Ā  A few notes about our upgrade:
      • This is SYS/SYP layer data only;Ā  I deleted all the upper layers in AX2012 before I started this process
      • I have tried both 10.7 and 10.9 versions of the upgrade package with the same results
      #FinanceandOperations #Technical #AdvancedĀ #DeploymentandImplementation
      Regards,????
      Corey Vantilborg
      ERP Analyst
      Tigercat International Inc.
      Brantford ON
The discussion ‘AX2012R2 > D365 Data Upgrade Failed on AdditiveSync’ is closed to new replies.
