AX2012 R3 SSRS report – connection closed
Posted by DSC Communities on November 12, 2020 at 11:12 am-
Predrag Nikodijevic
MemberNovember 12, 2020 at 11:12 AM
Hi All,
Ā i have a SSRS report, running from AX 2012 R3, which is receiving error message in Production environment. The error is –Ā
“An existing connection was forcibly closed by the remote host.”
It happens almost exactly at 5 minutes of execution time. In other environments, it runs successfully, takes about 10-15 mins to finish, depending on data volume.
-First i tried optimizing the underlying queries, with no significant performance improvement. Same with creating indexes on specific tables.
-Then, i tried different settings on SSRS report side – increasing timeout and execution time to 30 mins. Still it would error out at 5 min mark.
-Finally, In production, on both host and SSRS client end, we set the “sendtimeout” and “receivetimeout” to 30 minutes for “QueryServiceBinding”.However, by default, “MetadataServicebinding” at server end is set as following:
<binding name=”MetadataServiceBinding” sendTimeout=”00:05:00″ receiveTimeout=”00:10:00″ maxBufferSize=”1048576″ maxBufferPoolSize=”3145728″ maxReceivedMessageSize=”1048576″ listenBacklog=”200″ maxConnections=”200″>
So we changed the sendTimeOut to 10 mins.
The report is still failing after 5 mins. The setting s on the other environments, both client, AOS, or Reporting server, are the same, yet the report is coming out fine.
Any suggestions, where else may i look for the source of an error?The captured log from Reporting sever:
library!ReportServer_0-1!2c0!11/11/2020-01:26:41:: i INFO: RenderForNewSession(‘/DynamicsAX/AVANIHBBankReconcilationReport.Report’)
processing!ReportServer_0-1!2c0!11/11/2020-01:31:54:: e ERROR: Throwing Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: , Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset ‘BankRecon_DS’. —> System.InvalidOperationException: An exception occurred in the query metadata execution. The exception is The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ’00:30:00′.. —> Microsoft.Dynamics.AX.Framework.Services.Client.QueryServiceException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ’00:30:00′. —> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ’00:30:00′. —> System.IO.IOException: The read operation failed, see inner exception. —> System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ’00:30:00′. —> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
Ā Ā at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Ā Ā at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing)
Ā Ā — End of inner exception stack trace —
Ā Ā at System.ServiceModel.Channels.SocketConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)
Ā Ā at System.ServiceModel.Channels.DelegatingConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)
Ā Ā at System.ServiceModel.Channels.ConnectionStream.Read(Byte[] buffer, Int32 offset, Int32 count, TimeSpan timeout)
Ā Ā at System.ServiceModel.Channels.ConnectionStream.Read(Byte[] buffer, Int32 offset, Int32 count)
Ā Ā at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)
Ā Ā at System.Net.Security.NegotiateStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
Ā Ā at System.Net.Security.NegotiateStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
Ā Ā at System.Net.Security.NegotiateStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
Pedja Nikodijevic
Express Scripts Canada
Mississauga
DSC Communities replied 4 years, 9 months ago 1 Member · 0 Replies -
The discussion ‘AX2012 R3 SSRS report – connection closed’ is closed to new replies.
