AX user is disabled in Management reporter
  • AX user is disabled in Management reporter
    Posted by nazimlalji@hotmail.com on January 23, 2019 at 3:09 pm
    • Najeem JanatAli
      January 23, 2019 at 3:09 PM
      Hi All
      AX user came back from leave and account is activated in AX. However in Management reporter its still disabled.
      Selected the user, right click-modify but its not allowing to uncheck the disable check mark.Ā
      Disabled option is greyed out
      Any suggestion to that how to activate user accountĀ
      Thanks and kind regards
      Nazim Lalji
      Dynamics AX Analyst
    • Mark Zerr
      January 24, 2019 at 10:10 AM
      There is a a AccountDisabled field in the Reporting.SecurityUser table in the MR DB which you can flip back to 0.Ā  However I would check the Configuration Console log.Ā  In the end it’s not syncing back up with AX.Ā  A restart of the MR server wouldn’t hurt either and give it time to cycle through a full integration.Ā  Hopefully not the case here but I have experienced where MR seemed to just stop letting me add or disable users and I just did export of the reports and a rebuild. Good Luck
      Mark Zerr
      AX Technical Analyst
      New Sunshine LLC
      Indianapolis IN
    nazimlalji@hotmail.com replied 6 years, 7 months ago 1 Member · 0 Replies
The discussion ‘AX user is disabled in Management reporter’ is closed to new replies.
