AX Cube Deployment Process
  • AX Cube Deployment Process
    Posted by DSC Communities on January 29, 2017 at 11:09 am
    • Andy Norton
      January 29, 2017 at 11:09 AM
      We’ve started work on some custom cubes using AX and VS. At the moment we’re constructing our Perspective in the AOT, adding the data tables and views and setting the relevant Attributes and Measures etc.
      When we deploy the changes to the server through AOT deployment using the Business Information Tools menu everything works as expected. However we sometimes need to add Calculated Measures and also define extra dimensions, so open the generated Visual Studio project through the AOT. We make the changes we need and deploy to the server, again everything works fine.
      But when we need to change anything in the Perspective AOT again, and deploy through AX again, we lose the changes we’re making in Visual Studio. I’ve tried re-importing the generated project into the AOT but it doesn’t seem to make any difference.
      A few things that always seem to revert are
      – any calculated measures
      – the default deployment settings in VS (connection string and server)
      – any changes to dimensions
      So, my question is – is there anything specific we need to do to make sure that when we’re making changes after opening the project in Visual Studio, they filter back to the AOT and nothing is lost, as doing a reimport of the project (right clicking in the AOT area for Analysis Services Projects) doesnt seem to actually work for us.
      I’d appreciate any advice on where we’re going wrong.
      AX 2012 R2
    • Janja Nolan
      January 31, 2017 at 3:14 AM
      We also develop custom cube from AX iin visual studio from wherescape red.
      Janja Nolan
      BA
      Westland Milk Products
      Hokitika
    • Blaine McGillivray
      February 6, 2017 at 1:06 PM
      I am working with Jet Reports with super results. The Jet Data Manager let me stand up a Dynamics AX Sales Cube and Finance Cube in about a week. The support has been terrific too. Please contact me if you want more information.  Blaine 780 918 6165
      Blaine McGillivray
      Food Services of America
      Scottsdale, AZ 85254 AZ
    • Ron Hendrickson
      January 30, 2017 at 9:32 AM
      Well, I will stick my neck out here, since I have only a small amount of working in this area, but as I remember, you can’t make changes to the perspective after you have deployed, without losing the VS project and its changes. You have to get your perspective correct with all the tables, views, queries, etc. exactly right, and then make your changes in VS.
      I certainly hope šŸ™‚ I am right, I think I am.  There should be others who can either confirm or deny this. Best wishes, custom cubes within Dynamics AX are no picnic.
      Ron Hendrickson
      Sr. Project Manager
      Luck Stone Corporation
      Richmond VA
    • Jonathan Boott
      January 30, 2017 at 9:37 AM
      Andy,
      We’ve also built custom cubes in SSAS, for later analysis using Tableau.  Our approach was custom ETL out of the AX database rather than the built-in cube definitions.  We’ve had a very good experience; happy to share more with you if any interest.
      Jonathan Boott
    DSC Communities replied 8 years, 8 months ago 1 Member · 0 Replies
The discussion ‘AX Cube Deployment Process’ is closed to new replies.
