Attention information from PR to PO
  • Attention information from PR to PO
    Posted by nazimlalji@hotmail.com on April 21, 2020 at 1:00 pm
    • Najeem JanatAli
      April 21, 2020 at 1:00 PM
      Hi All
      Attention information is entered in Purchase requisition. Its not appearing in Purchase order. Any suggestion is any set up is missing or have to activate any field in AOT
      Thanks and best regards
    • Ian Gorman
      April 21, 2020 at 2:02 PM
      Najeem,
      My attention fields pull in just fine on the PurchTable and PurchLine.
      You may want to check LCS or with a developer to see if your updateFromPurchReqLineMap class doesn’t contain a reported bug or isn’t customized.
      Here’s the standard R3 app version 6.3.6000.149 class:
      /// <summary>
      ///  Update <c>PurchTable</c> from <c>PurchLine</c> or <c>PurchReqLine</c>.
      /// </summary>
      /// <param name="_listEnumerator">
      /// A list enumerator contains recrods from <c>PurchLine</c> or <c>PurchReqLine</c>.
      /// </param>
      public void updateFromPurchReqLineMap(ListEnumerator _listEnumerator)
          InventSiteId                    siteId;
          InventLocationId                locationId;
          LogisticsPostalAddressRecId     addressRecId;
          Addressing                      deliveryAddress;
          AddressZipCodeId                deliveryZipCode;
          AddressCountyId                 deliveryCounty;
          AddressCountryRegionId          deliveryCountryRegionId;
          AddressStateId                  deliveryStateId;
          VendName                        deliveryName;
          AddressCity                     deliveryCity;
          AddressStreet                   deliveryStreet;
          LogisticsPostalAddress          postalAddress;
          PurchReqAttention               attention;
          DimensionDefault                dimension;
          RecId                           requesterRecId;
          InventDim                       inventDim;
          PurchReqLineMap                 purchReqLineMap;
          boolean                         first           = true;
          boolean                         setSiteId       = true;
          boolean                         setLocationId   = true;
          boolean                         setAddress      = true;
          boolean                         setDim          = true;
          // Only related to purchReqLine
          boolean                         setAtt          = true;
          boolean                         setReq          = true;
          ProdId                          projId;
          while (_listEnumerator.moveNext())
              purchReqLineMap = _listEnumerator.current();
              postalAddress   = LogisticsPostalAddress::findRecId(purchReqLineMap.DeliveryPostalAddress);
              inventDim       = InventDim::find(purchReqLineMap.InventDimId);
              if (first)
                  first                   = false;
                  siteId                  = inventDim.InventSiteId;
                  locationId              = inventDim.InventLocationId;
                  addressRecId            = purchReqLineMap.DeliveryPostalAddress;
                  deliveryAddress         = postalAddress.Address;
                  deliveryZipCode         = postalAddress.ZipCode;
                  deliveryCounty          = postalAddress.County;
                  deliveryCountryRegionId = postalAddress.CountryRegionId;
                  deliveryStateId         = postalAddress.State;
                  deliveryName            = purchReqLineMap.DeliveryName;
                  deliveryCity            = postalAddress.City;
                  deliveryStreet          = postalAddress.Street;
                  dimension               = purchReqLineMap.DefaultDimension;
                  if (purchReqLineMap.TableId == tableNum(PurchReqLine))
                      attention           = purchReqLineMap.Attention;
                      requesterRecId      = purchReqLineMap.Requisitioner;
                      projId              = purchReqLineMap.ProjId;
              else
                  setSiteId       = setSiteId     && (siteId          == inventDim.InventSiteId);
                  setLocationId   = setLocationId && (locationId      == inventDim.InventLocationId);
                  setDim          = setDim        && (dimension       == purchReqLineMap.DefaultDimension);
                  setAddress      = setAddress
                                 && deliveryAddress         == postalAddress.Address
                                 && deliveryZipCode         == postalAddress.ZipCode
                                 && deliveryCounty          == postalAddress.County
                                 && deliveryCountryRegionId == postalAddress.CountryRegionId
                                 && deliveryStateId         == postalAddress.State
                                 && deliveryName            == purchReqLineMap.DeliveryName
                                 && deliveryCity            == postalAddress.City
                                 && deliveryStreet          == postalAddress.Street
                                 && addressRecId            == purchReqLineMap.DeliveryPostalAddress;
                      setReq = setReq && (requesterRecId  == purchReqLineMap.Requisitioner);
                      setAtt = setAtt && (attention       == purchReqLineMap.Attention);
          this.InventSiteId          = setSiteId     ? siteId : '';
          this.InventLocationId      = setLocationId ? locationId : '';
          this.DeliveryPostalAddress = setAddress    ? addressRecId : 0;
          this.DeliveryName          = setAddress    ? deliveryName : '';
          if (setDim)
              this.DefaultDimension = dimension;
              this.ReqAttention   = setAtt ? attention : '';
              this.Requester      = setReq ? requesterRecId : 0;
              this.ProjId         = projId;
              this.CurrencyCode   = purchReqLineMap.CurrencyCode;
              this.AccountingDate = purchReqLineMap.TransDate;
      Ian Gorman, PMP, MCSE
      Senior Consultant
    • Najeem JanatAli
      April 21, 2020 at 3:29 PM
      Thanks Ian
      Since we have multiple instances so checked and compared mapping in AOT and its same and no sign of any changes
      Anything is missing on Enterprise Portal or parameter set up
      Thanks and kind regards——————————————-
    nazimlalji@hotmail.com replied 5 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Attention information from PR to PO’ is closed to new replies.
