Atlas 6.1 Filtering
  • Atlas 6.1 Filtering
    Posted by DSC Communities on May 12, 2020 at 4:31 pm
    • Daren Teng
      May 12, 2020 at 4:31 PM
      Hi All,
      I am trying to filter an Atlas 6.1 report by excluding more than 1 value for a column. I tried using the NOT EQUAL (!=) operator on a single value and it works just fine, however, it does not work if I want to exclude multiple values. It however, works if I include multiple values in the filter, but that will not work in the long run as I would have to keep adding new values in, thus, excluding 2 out of 100 is way quicker than including 98 out of 100.
      e.g. !=ABC,!=DEF does not work, !=ABC,DEF does not work, !=ABC||!=DEF does not work, !=ABC||DEF does not work as well.
      Is there a specific way to code it?
      Daren Teng
      Data Analyst | Business Intelligence Specialist
    • Guy Terry
      May 13, 2020 at 5:37 AM
      If you want to pass a value to Atlas, you don’t need the equals sign. This works just fine:
      Guy Terry
      Application Consultant
      Annata
    • Daren Teng
      May 15, 2020 at 3:13 PM
      Thank you, this works fine!
      Daren Teng
      AGI-MFS/YORK/STORMOR/BROWNIE
      Grand Island
    • Steve Latta
      May 13, 2020 at 8:34 AM
      You don’t need the = sign. Just format like this:
      !ABC,!DEF,!GHI
      You can even mix with values you want:
      A..F,!D..E
      Which would return A,B,C,F.
      Steve Latta
      Accountant
      Ortec, Inc.
      Easley SC
    • Matt McMains
      May 13, 2020 at 9:11 AM
      ?Daren,
      Try your first option again, and this time remove the “=’ signs.
      !ABC,!DEFĀ
      I am currently on 6.1 and frequently filter in this manner.
      Matt McMains
      Stauffer’s Biscuit Company
      York PA
    • Amy Akley
      May 13, 2020 at 9:04 AM
      Daren,
      You should be able to use !ABC,!DEF
      Amy Akley
      Sr. Financial System Analyst
      XTRA Lease
      Saint Louis MO
The discussion ‘Atlas 6.1 Filtering’ is closed to new replies.
