We have hundreds of invoices that are posted to the system with defined terms however, the Aging report is reporting them incorrectly.Ā This has resulted in late payments to vendors.Ā Has anyone else experienced this?
—————————— Jennifer Vanselow Augeo Affinity Marketing St. Paul MN ——————————
Christopher Ho Yee
August 30, 2019 at 12:45 PM
Hi Jennifer,
Just for clarity, have you confirmed if the due dates themselves are incorrect or is the Aging report not aging them as desired?
—————————— Christopher Ho Yee Altius Consulting Richmond BC —————————— ——————————————-
Jennifer Vanselow
August 30, 2019 at 12:50 PM
The terms (due dates) are set up correctly.Ā It is that the aging report is not calculating them correctly.
—————————— Jennifer Vanselow Augeo Affinity Marketing St. Paul MN —————————— ——————————————-
Donald Jenkins
September 4, 2019 at 8:49 AM
Jennifer; if the ‘due date’ on the invoice is correct, then I would suspect you are using an ‘Aging Period Definition’ when you generate the report, and it is setup incorrectly.Ā Go to Accounts Payable –> Setup –> Aging Period Definitions, and look at the setup.Ā The setup in there determines the buckets, but there are a number of parameters on the report screen that could impact the output.
However the aging report would not prevent the invoices from being paid on-time.Ā The invoices selection criteria in the payment proposal process is determining that.Ā Are you sure that the user generating the payment proposal has the correct settings in those parameters?
—————————— Donald Jenkins Avanade, Inc. Maryville TN —————————— ——————————————-
