Alpha Key missing from bottom of data
Joyce Mackiewicz
Joyce MackiewiczApr 26, 2022 06:50 PM
Hello and thank you to everyone who supports this forum, I am wondering if anyone knows where I can …
1.Joyce Mackiewicz
Posted Apr 26, 2022 06:50 PM
Hello and thank you to everyone who supports this forum,I am wondering if anyone knows where I can turn on the “alpha key” that appears below queried results.
Interestingly enough, this key is still visible when records appear in sections of dashboards, but when I select the ‘see all records’ commands, the alpha key disappears.
Not sure if it matters> I’ve opened CRM in the following browsers: EDGE or CHROME,
as of> Microsoft Dynamics 365 2022 release wave 1 enabledOne of my users noticed this, and I am also affected by whatever caused this to happen.
Any insight is greatly appreciated.
Joyce Mackiewicz
Sales Operations, CRM Business Analyst
Sekisui Diagnostics, LLC
One Wall Street
Burlington, MA 01803
USA
Joyce Mackiewicz
Sekisui Diagnostics
Lexington MA
——————————2.
TOP CONTRIBUTOR
Niels Søgaard Lønberg
Posted Apr 27, 2022 02:35 AM
@Joyce Mackiewicz you can see how to enable the jumpbar in this video.——————————
Niels Lønberg
Digital Sales Specialist
Semco Maritime
——————————3.
GOLD CONTRIBUTOR
Jeff Woodard
Posted Apr 27, 2022 08:18 AM
Also cross reference this post: Alphabet Bar not visible after new update | Customer Engagement & Dynamics CRM Forum (crmug.com)#JumpBar #search #CustomControl
Jeff Woodard
Chief Technical Officer
Transportation Financial Services, Inc.
West Palm Beach FL
——————————4.
Cynthia Lagueux
Posted Apr 27, 2022 08:54 AM
Good morning Joyce –
This feature was removed in Wave 2 – what were they thinking?
It can be turned back on by individual entity, it was discussed in a post here on Oct. 13/21:
Go to Settings – Advanced Settings – Settings (dropdown) – Customizations – Customize the system – Entities – <select the entity you want to customize> – Controls – Add Control – Select “Power Apps Grid” and then enable the Jump bar setting.
>> Save & Publish the changes.However, we have a large number of entities, and in that post was also that Microsoft can turn it on for all the table in the environment, so I submitted a ticket. After a bit of pushback that I could do it myself individually, they were quick to complete my request.
Hope this helps,
Cynthia——————————
Cynthia Lagueux
Special Olympics Canada
ON
——————————5.
SILVER CONTRIBUTOR
Nataliya Tsyplakova
Posted Apr 27, 2022 09:32 AM
Hi Joyce,Please try to apply Power Apps Read-Only Grid control on the table and enable the Jump bar.
Nataliya Tsyplakova
World Vision Canada
——————————6.
Joyce Mackiewicz
Posted Apr 27, 2022 11:33 AM
Thank you all for your advice and providing the video link.I successfully updated the controls for each entity.
from here:OPEN each ENTITY where I wanted the alpha key to appear
OPENEND CONTROLS TAB
CLICKED ADD CONTROL
FIND AND SELECT “POWER APPS READ-ONLY GRID” and ADD
Once added, select/highlight it (2.1) and EDIT the ‘Jump Bar’ find/select ENABLE (video was a little different from my experience)
Be sure to select the engagement area where the Power App Read-only Grid will be shown: Web, Phone, and/or Tablet
Save and Publish
New control (highlighted in blue)——————————
Joyce Mackiewicz
Sekisui Diagnostics
Lexington MA
——————————7.
SILVER CONTRIBUTOR
Sandra Devin
Posted Apr 27, 2022 12:58 PM
The wave 1 2022 update that went live this past weekend is the culprit to the view changes. I have found that for system views you can add the ‘read only grid’ control and set it as the default, and that will restore the alphabet bar. This update forced the ‘read only grid (default)’ as the default for views. Unfortunately this means updating every system view. I have not found a way to update personal views. If someone has a more general solution I would love to hear it!You can also change the view to an editable grid (users can often do this themselves by using the ‘show as’ in the ribbon to switch to editable, if its enabled for the entity).
The screen shot below shows how I changed one view to get the alphabet bar back.
Sandra Devin
CRM Analyst
National CineMedia
Denver CO
The discussion ‘Alpha Key missing from bottom of data’ is closed to new replies.
