2012 Transfers
  • 2012 Transfers
    Posted by DSC Communities on November 20, 2017 at 11:32 am
    • Darla Phillips
      November 20, 2017 at 11:32 AM
      ?Hi Everyone!
      We are having a bit of trouble truly understanding how to utilize the Transfer function in AX. We would ideal like it to work as our regular transfers do and create a packing slip and BOL. However, it does not seem to do that.
      I am reaching out to see how the rest of the world uses this feature and what customizations might have been made to get more functionality out of it.
      TIA
      Darla Phillips
      Business Systems Analyst
      Paragon Films, Inc.
      Broken Arrow OK
    • Nandita Nityanandam
      December 4, 2017 at 6:53 AM
      There is no BOL and Packing slip in Transfer journal as well as transfer order, both the functionality is different to each other.
      Nandita Nityanandam
      Marketing Head
      Indusa HQ – USA
      Oakbrook Terrace IL
    • Jeroen Paans
      December 4, 2017 at 10:13 AM
      Hi Nandita,
      Did you look into Logistics -> Inquiries -> Bill of Lading? There is a print button on top of it. Maybe this can help.Ā
      Jeroen
      Jeroen Paans
      Driscoll’s
      Breda
    • Sean Blais
      November 20, 2017 at 1:32 PM
      A Transfer order instead of a Transfer journal should get you what you need… Which are you using?
      Thanks, Sean
      Sean Blais
      Operations Support
      Sutphen Corporation
      Dublin OH
    • Lynn Litzau
      November 20, 2017 at 2:02 PM
      Hi Darla,
      Can you please confirm which transfer function you are currently utilizing?Ā  There are transfer journals and transfer orders in the system.Ā  The transfer order contains a picking and BOL functionality.Ā  Which are you using?
      Best regards,
      Lynn Litzau
      Dynamics Consultant
      Ascent Innovations LLC
      Schaumburg IL
    • Amanda Harris
      November 20, 2017 at 1:23 PM
      ?Hey Darla-
      We’re working on implementing transfer orders to move materials between warehouses. We have a combination of managed and unmanaged warehouses in 2012 R3, so we have a variety of scenarios in terms of how we’re using transfer order functionality. We’re also planning a customization that allows you to create transfer orders using a unit other than the inventory unit of measure. We’re a meat manufacturer, so our items are all set up with LB as the inventory unit. Our warehouse workers are more familiar with Cases and pallets though and want the ability to create a transfer order for 3 pallets of an item or 20 cases of it, for example. We’re not done with our transfer order set up, or the customization, but I’d be happy to share more information with you.
      Amanda
      Amanda Creedon
      IT Business Analyst
      Kayem Foods Inc.
      Chelsea MA
    DSC Communities replied 7 years, 9 months ago 1 Member · 0 Replies
The discussion ‘2012 Transfers’ is closed to new replies.
