Reply To: WMS Enabled Items
  • Suf Hayes
    January 19, 2024 at 2:59 pm
    You should be able to setup a non WMS enabled warehouse, but assign it a default location and then be able to process the same items through that warehouse. You can set this default location as the default receipt and issue location on the warehouse and everything should flow through this location. The location itself is pretty meaningless but it’s needed if you want to use the same items in both WMS enabled and non WMS enabled warehouses.
    We use WMS enabled warehouses for most of our items, but have some offsite warehouses and a drop ship warehouse that are non WMS enabled and process through just fine, but with a default location.
    You may need to create a default aisle etc to make that location, but that should just be one time setup.
