A few other things to consider: Does weight factor in on how much can be put on the pallet? Or is it just dimension?
There are some ISV products that calculate containers, perhaps they can be adapted to do a pallet, it’s a similar thing.
For your finished goods are they make to order where the dimensions would be different on a regular basis? Or can you estimate the dimensions. What happens you are off a little bit?
This could be a power app depending on the process flow.
Just a few thoughts. Good luck!
Login
Block Member?
See blocked member's posts
Mention this member in posts
Invite this member to groups
Message this member
