Year End Close
  • Posted by DSC Communities on June 19, 2017 at 8:30 am
    • Frances Higgins
      June 19, 2017 at 8:30 AM
      ?We are getting ready to do our first year end close.Ā  Over our first year with NAV we have made some changes in our chart of accounts that has resulted in blocking some accounts and dimensions.Ā  The closing entries cannot seem to generate without all of these accounts being ‘unblocked’Ā  Our developer has suggested that we use the data migration function to export tables, unblock accounts, re-import the table, run the closing entry then re-import the original tables that have the fields blocked.Ā  I am hesitant to mess with tables and wonder if there is another way to run closing entries without un-blocking accounts and dimensions.
      Frances Horch
      University of Winnipeg
      Winnipeg MB
    • David Wiser
      June 19, 2017 at 11:05 AM
      Unfortunately, that is the process. Ā It sounds messy, but it’s not really too bad. Ā You can use RapidStart to do the export and imports of the chart of accounts and the dimension tables, unless your partner has another solution.
      Dave Wiser
      Beckwith & Kuffel
      Seattle WA
    • Geovanny Fuentes
      June 20, 2017 at 11:49 AM
      Frances correct seems like a lot but until you get yourself into a proper routine, the work needs to get done.
      I suggest performing this in a test database.
      Follow all procedures and write them down as you make corrections.
      This way you 1st EOY comes out good in your test sandbox database.
      P.s. Remember to the steps being suggested.
      Good luck.
      5 Steps for Year-End Closing in Microsoft Dynamics NAV
      Tribridge remove preview
      This blog is part of our Customer Care series , where our experts address technical implementation and service questions across the Tribridge product portfolio to assure that customers have the support they need to optimize their solution most effectively and efficiently. It’s hard to believe it’s that time of year again!
      View this on Tribridge >
      Microsoft Dynamics NAV 2015: How to Run the Close Year End Process
      ArcherPoint, Inc. remove preview
      In Microsoft Dynamics NAV 2015, the Close Income Statement batch job transfers the year’s results to a Retained Earning account in the balance sheet and closes all of the income statement accounts. This process creates a journal, which is posted manually.
      View this on ArcherPoint, Inc. >
      Geovanny Fuentes
      San Diego CA
    • Devang Mehta
      June 22, 2017 at 9:38 AM
      ?Frances,
      I am going to assume there are balances in these blocked accounts and you need them closed out to your retained earnings accounts ? Perhaps you have thought of this, but how about re-classing those balances to your new accounts ?
      Devang Mehta
The discussion ‘Year End Close’ is closed to new replies.
