Writing custom packing slip and trying to find correct tables
  • Writing custom packing slip and trying to find correct tables
    Posted by DSC Communities on July 22, 2018 at 11:28 pm
    • Paul Silvani
      July 22, 2018 at 11:28 PM
      We are trying to write a custom packing slip off of the warehouse shipment table.Ā  This is before the shipment is posted.Ā  We are lot tracking the inventory, and for one item on the warehouse shipment, there can be multiple lots.Ā  On the packing slip, we are trying to show the different lot numbers and associated quantities for each lot.Ā  The challenge is that we cannot find the correct tables to pull the lots and quantities.Ā  Does anyone know which table has the lots and quantities for the warehouse shipments?
      Paul Silvani
      General Manager
      Velosio
      Chicago IL
    • Nick Yancer
      July 23, 2018 at 8:52 AM
      You can pull lot/quantities from the Warehouse Activity Line table once the items have been picked. This table is linked to the Warehouse Shipment document.
      Nick Yancer
      NAV Developer
      Advanced Media Technologies
      Deerfield Beach
    • Tijane Ndiongue
      July 23, 2018 at 9:43 AM
      ?Hi,
      I think this depends on your process. If your warehouse is using “Directed Pick and Put-Away” then you can get the lot numbers from the pick lines. However the safest bet is to go to the “Reservation Entry” and filter on theĀ sales line that is the source of your warehouse shipment line.
      Also if the document has been partially posted then the lot numbers and quantities will found in the “Tracking Specification” table. So you will have to merge to information on both “Reservation Entry” and “Tracking Specification” of the source document line for the warehouse shipment line.
      Tijane Ndiongue
      Forum Energy Technologies
      Houston TX
    • Geovanny Fuentes
      July 24, 2018 at 2:28 PM
      Keep aware of Assembly components since those are in the Reservation Entry table with a different “Source Type”=900 versus “37”Sales Line.
      The Assembly components will have the correct Lot No.’s being used and Quantities.
      Good luck.
      Geovanny Fuentes
      San Diego CA
    DSC Communities replied 7 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Writing custom packing slip and trying to find correct tables’ is closed to new replies.
