Where are Table Name and Field Name stored for NAV
  • Where are Table Name and Field Name stored for NAV
    Posted by DSC Communities on June 29, 2018 at 3:03 pm
    • Marco Villarreal
      June 29, 2018 at 3:03 PM
      Hi Everyone,
      I am trying to write a stored procedure in SQL server that pulls information from the [Change Log Entry] table so we can easily keep track of what changes have been made in NAV. The only problem is that I cannot find a table that includes the [Table Name] and [Field Name] for the corresponding columns [Table No_] and [Field No_] in the [Change Log Entry] table.Ā
      Where can I find Table Name and Field Name? Is this information in the database?
      I am working with NAV 2016.
      Thank you for your help!
      Marco Villarreal
      Farmers Investment Co
      Sahuarita AZ
      June 29, 2018 at 3:18 PM
      ?Table 2000000041 – Field
      You won’t see it in Object Designer but it is available if you try to create a page or report using it.
      NAVUG Programming Committee
      NAVUG Membership Committee
    • Franz Kalchmair
      June 30, 2018 at 3:19 PM
      actually the virtual tables within nav wont help you.
      can only be used within nav, in the nav dev. client.
      table names: stored invirtual tablesĀ AllObj, AllObjWithCaption
      fields: stored in virtual table Field
      these virtual tables can then be used in pages, reports, etc.Ā
      in your case you need access in sql. it’s quite different. so …
      to get the tables names you can use table dbo.Object.
      to get the field names in sql you can use the sql system tables, e.g.
      select COLUMN_NAME from INFORMATION_SCHEMA.COLUMNS
      where TABLE_CATALOG = <databasename>
      and TABLE_NAME = <tablename>
      — and ORDINAL_POSITION = <field no.>
      Franz Kalchmair
      Microsoft MVP
      Senior Consultant
      Austria, Europe
    DSC Communities replied 7 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Where are Table Name and Field Name stored for NAV’ is closed to new replies.
