Undo Shipment from Prior Period
Posted by David Wiser on February 14, 2017 at 6:43 pm-
I’m afraid that the answer is “no”, but is it possible to undo a sales shipment that was posted in the previous (and now closed) period? Scenario: Posted shipment on 1/31/17. Closed January. Now on 2/14/17 discovered shipment was in error and desire to undo the shipment, but not reopen January. Sales order has not been invoiced.
Dave Wiser
Beckwith & Kuffel
Seattle WA
Alex Chow
MemberFebruary 14, 2017 at 10:12 PM
As long as the invoice is not posted, you can undo shipment. Are you getting errors when you do so?Dynamics NAV does not have a “hard” close. So that means the allow posting from/to dates are controlled in the General Ledger Setup or the User Setup.
Alex Chow
Dynamics NAV MVP
AP Commerce
Los Angeles CA
I agree with Alex, as long as the invoice isn’t posted you should be able to undo the shipment if you open up the posting dates. Just be aware that this will affect the GL balances for the prior month that the shipment was posted.
Joe Shields
Advanced Media Technologies
You can definitely undo the shipment. If you are using directed putaway and pick, you will have to use a Whse Internal Putaway to move the returned inventory from your shipping bins back to pick or putpick bins.
NAVUG Programming Commitee
NAVUG Membership Committee
Lewis is correct, if you are using directed pick and putaway it is important to move the inventory back to the right bin.
This is also the case if you haven’t made a shipment yet but have registered a pick and then need to delete the warehouse documents for some reason.
Joe Shields
Alex Chow
MemberFebruary 17, 2017 at 2:46 AM
I wrote a blog on how to do this with Directed Pick and Put-away. It’s for PO Receipt, but it’s the same process for shipments except you go to the sales side instead of the purchase side.Confessions of a Dynamics NAV Consultant
Dynamicsnavconsultant remove preview Confessions of a Dynamics NAV Consultant Overview Undo receipt has become a necessity in some warehouse environments where the staff may not be able to keep up with the paper flow. Strictly speaking, the undo receipt process shouldn’t be necessary because the process in place should be able to accommodate. View this on Dynamicsnavconsultant > ——————————
Alex Chow
Dynamics NAV MVP
AP Commerce
Los Angeles CA
Adam Hacker
MemberFebruary 15, 2017 at 9:04 AM
If you have closed the inventory period you will also have to reopen it to allow the undo shipment to process. As previously stated this will effect prior period GL balances.——————————
Adam Hacker
Financial Analyst
Home Hardware Stores Limited
St Jacobs ON
David Wiser replied 7 years, 10 months ago 1 Member · 0 Replies -
The discussion ‘Undo Shipment from Prior Period’ is closed to new replies.
