Standard Purchase Codes
  • Standard Purchase Codes
    Posted by DSC Communities on August 21, 2019 at 5:30 pm
    • Amy Becker
      August 21, 2019 at 5:30 PM
      This may be a very simple questions, but can Standard Purchase Codes be set up based on %’s rather than static amounts?
      We are currently on NAV 2013 R2
      thanks,
      Amy Becker
      Marshall Wolf Automation
      Algonquin IL
    • Peter Zentner
      August 22, 2019 at 8:21 AM
      Hi Amy,
      Standard Purchase Codes can only have lines setup with quantities defined in standard NAV. Depending on what your exact requirements are, you would have to modify the system to get working what you would want to achieve.
      Peter Zentner
      Director of Product Management
      NAV-X
      Holmdel NJ
    • Alfredo Zelaya
      August 22, 2019 at 8:54 AM
      Hello Amy
      What Peter mentioned is completely spot-on. Can you elaborate on what you are trying to accomplish? Maybe another group member may have some insight and will pass on advise.
      Alfredo Zelaya
      Sr. Systems Analyst
      Megadyne Americas LLC
      Fairfield NJ
    • Amy Becker
      August 22, 2019 at 9:15 AM
      On a very simple level,I would like to take a phone bill and put 50% to Admin and 50% to Sales.Ā  Every month the invoice will be a different value but I want to keep the split at 50/50.Ā  I was hoping this was built into the system.
      Amy Becker
      Algonquin IL
    • Cynthia Priebe
      August 22, 2019 at 9:26 AM
      You may want to consider using the Recurring General Journal Allocations to accomplish some of all of this task.
      Cynthia Priebe MCP, DCP
      Liberty Grove Software
      I would love to see you at Summit 2019!
      GET67 – Small Changes with Big Impact: Core Application Setup and Configuration
      ADM60 – Mods: Just Because Everyone Does Them Doesn’t Mean You Should
      FIN58 – (with Andrea Riviezzo) My AP Person Just Left, Now What?
    • Alfredo Zelaya
      August 22, 2019 at 9:41 AM
      In addition, you can look at applying Dimension values to the line when creating the Purchase Invoice:
      Create a line for “Admin” and another for “Sales” and apply the proper Dimension value to each line.
      Many ways to handle this.
      Alfredo Zelaya
      Sr. Systems Analyst
      Fairfield NJ
    • Peter Zentner
      August 22, 2019 at 10:00 AM
      There were two to beat me to this – both answers are spot on. I would have suggested probably the recurring journal.
      This is exactly what it’s meant for. However, you wont be entering a full purchase document, so it would not be as easy to, for instance, tag the original vendor invoice as a pdf to it. But it is a very easy and quick way to add allocations on a recurring basis where the allocation stays the same, but the amount changes.
      Peter Zentner
      NAV-X
      Holmdel NJ
    DSC Communities replied 6 years ago 1 Member · 0 Replies
The discussion ‘Standard Purchase Codes’ is closed to new replies.
