SQL Error ” Could Not find Prepared Statement with Handle 12511″
  • SQL Error ” Could Not find Prepared Statement with Handle 12511″
    Posted by DSC Communities on August 8, 2019 at 8:26 am
    • Guy Famelart
      August 8, 2019 at 8:26 AM
      It looks like it is coming from Web services
      SQL is setup with unlimited connections
      Anybody got this error and a solution to fix it.
      We are on NAV 2017
      Guy Famelart
      Senior Manager of IT
      Skyfold inc.
      Baie d’UrfĆ© QC
    • Peter Zentner
      August 22, 2019 at 8:30 AM
      Hi Guy,
      I am not sure, if this is still an issue. Since I am not sure what SQL version you are using, it could be a lot of things. There are different topics around that when you search for the error message, but they are all pointing to different things. One of the main things seems to be that, if you are running on an older SQL Server and the version is not supported, it can throw errors like that. Another topic points to some possible issue in the NAV server, but this is for an older version.
      So, what version of SQL are you using?
      Does this happen all the time (as soon as you start and work in NAV) or only once in a while?
      Do you have a way to replicate this behavior?
      Peter Zentner
      Director of Product Management
      NAV-X
      Holmdel NJ
    • Kyle Hardin
      August 23, 2019 at 7:35 AM
      Need more information. What is a user trying to do when the error message happens? Where are you seeing the error message – in a client? In SQL logs? In the server event viewer?
      Kyle Hardin
      NAV Developer
      ArcherPoint Inc.
      Duluth GA
    DSC Communities replied 6 years, 1 month ago 1 Member · 0 Replies
The discussion ‘SQL Error ” Could Not find Prepared Statement with Handle 12511″’ is closed to new replies.
