SMTP Error Sending Bulk Emails “net_io_connection closed” – Gmail
  • SMTP Error Sending Bulk Emails “net_io_connection closed” – Gmail
    Posted by DSC Communities on November 28, 2017 at 4:00 pm
    • no way
      November 28, 2017 at 4:00 PM
      Hello Everyone –Ā
      Does anyone have any diagnostic recommendations or solution ideas to an SMTP error received while sending bulk email?Ā
      The error is:Ā
      “The SMTP mail system returned the following error “Failure sending mail. Unable to read data from the transport connection: net_io_connection closed””
      We are using Gmail.
      –Ā
      Thank you in advance for any ideas or feedback!Ā
      Mickey
    • Ian Ray
      November 28, 2017 at 4:55 PM
      I’m not sure, but I have some guesses…
      You may either be hitting the ceiling for the number of recipients to one message (100) or the number of messages per day (2,000).
      If not, have you tried setting upĀ smtp-relay.gmail.com ? I have read that may work in certain conditions where login does not.
      Ian Ray
      Cypress Grove
      Arcata CA
    • no way
      November 28, 2017 at 5:40 PM
      Thanks Ian! We are comfortably under 2000 and the error is erratic in it’s timing.Ā
      We are considering whether or not it’s b/c of a timeout issue.——————————————-
    • Jojo Pornebo
      November 29, 2017 at 11:57 AM
      Does it randomly work?
      It could be the SMTP port you are using. Try port 587 in your SMTP port configuration or the TLS port that gmail requires. Your email protocol may be using SMARTTLS.
      Jojo Pornebo
      Jojo Pornebo
      Subok Na
      AUBURN CA
    • Val Gameiro
      November 29, 2017 at 1:19 PM
      It could be a timeout issue. You set a wireshark on your server to evaluate traffic to the SMTP server.
      Could also be a DNS issue – when you get that error, have you noticed any problems with DNS? Can you ping and traceroute the server?
      Val Gameiro
      Senior NAV Analyst
      BPL Plasma
      Austin, Texas
    DSC Communities replied 7 years, 9 months ago 1 Member · 0 Replies
The discussion ‘SMTP Error Sending Bulk Emails “net_io_connection closed” – Gmail’ is closed to new replies.
