setup changes across multiple companies?
Posted by DSC Communities on April 9, 2020 at 5:16 pm-
Benji Jasik
MemberApril 9, 2020 at 5:16 PM
we have many companies in our NAV instance and want to make changes across all of them in one screen (User Setup Allowed posting dates)
Is there a tool out there or sample code I can use to build something like this?
Thanks in advance.
Benji Jasik
Generate Capital
Spencer Coulter
MemberApril 10, 2020 at 7:55 AM
Benji,We’ve built similar tools in the past, generally the cleanest way is to define a “template” or master company that all changes are made in so that you only have to worry about the synch one way. Then you simply add listeners for table changes and push that through to the other companies using C/AL to switch company and copy information. We’ve done this for master data in the cases I can think of (COA, Dimensions, Customers, Vendors, etc) and even have a case where we did it for a cloud BC instance crossing between tenants.
Spencer Coulter
Director, Business ApplicationsRSM US LLP
D: 515.281.9248 F: 515.471.5261
E: Spencer.Coulter@rsmus.com
Benji Jasik
MemberApril 10, 2020 at 8:48 AM
Thanks. We do have a template company we make changes to first, but not the code to push those changes across the rest of our companies.Let me know if you would be willing to share any sample code or point me in the right direction
Benji
Benji Jasik
Generate Capital
Spencer Coulter
MemberApril 10, 2020 at 11:27 AM
Sure thing, so in general using the template will protect you from looping. In the template listen for the OnInsert, OnModify, OnDelete to fire logic. Once you’ve caught the interaction you can loop the Companies table and call a CHANGECOMPANY method to login to the other company. Inside of that you can simply call a GET for the table you are interacting with and a [Table].COPY(Rec) so that it copies the record into the other company.——————————
Spencer Coulter
Debbie Clark
MemberApril 14, 2020 at 11:00 AM
Hi Benji,
We have at tool that will push data across all the companies automatically called ConnectIT.Ā It is developed by idyn and we are the North American distributors which will work with your partner to get you the tool.Ā Please let me know if you need further information.Ā š——————————
Debbie Clark
Toronto Co-Chairperson,BCUG/NAVUG
Qixas Group Inc, Chief Operations Officer
dclark@qixas.com
Benji Jasik
MemberApril 15, 2020 at 1:32 AM
Can we get a demo directly or do we have to go through our partner (Innovia ?)——————————
Benji Jasik
Generate Capital
Debbie Clark
MemberApril 15, 2020 at 9:15 AM
Absolutely we can provide a demo.Ā Let’s connect privately.——————————
Debbie Clark
dclark@qixas.com
DSC Communities replied 5 years, 12 months ago 1 Member · 0 Replies -
The discussion ‘setup changes across multiple companies?’ is closed to new replies.
