Remaining Quantity – Item Ledger Entry
Posted by DSC Communities on June 16, 2020 at 12:49 pm-
Valarie Wiles
MemberJune 16, 2020 at 12:49 PM
It was recently discovered the our remaining quantity column in the item ledger entry table reflects mostly 0’s for all items with the exception of items received on a Purchase order.Ā Where do I look into why this column is not calculating the correct item quantity.Ā ĀNote, when I look at the applied entriesĀ for a particular transaction in the item ledger entry table, I see the quantity and remaining quantity reflect a value.Ā It’s just not showing up in the item ledger entry list.Ā
Thanks.
Valarie Wiles——————————
Jamie Constantine
MemberJune 16, 2020 at 2:07 PM
what version are you working in.Ā Ā what type of entry (purchase, sale, adjustment, etc)Ā has a zero remaining qty?Ā can you take a screen shot?Ā Ā the remaining qty is a flow field from the value entries (applied entries).Ā It is calculated because you sold a purchsae product or adjusted in through a journal.——————————
Jamie Constantine
Senior Consultant
Columbus Global
Valarie Wiles
MemberJune 16, 2020 at 2:16 PM
NAV 2018.Ā It looks like it’s consumption and sale entries that are all 0.——————————
Valarie Wiles
Goodwill Southeast Georgia
Savannah GA
You are seeing expected behavior. That is, after a Sales or Consumption transaction is completed there is notĀ Remaining Quantity since inventory is no longer available (it has been consumed into production or shipped out).Ā
You will seeĀ Remaining Quantity for transactions that bring inventory in to NAV (e.g. Purchase Receipt, Positive Adjustment, Sales Return Order, Production Output, Transfer Order Receipt) if the inventory has not been used up.
Andrew Good
President
Liberty Grove Software
Oakbrook Terrace IL
As Andrew stated, this is normal functionality.Ā Remaining Inventory is usually shown for “inbound” item entries (e.g. purchases, production output, etc.)Ā When “outbound” item entries are posted (e.g. sales, consumption, etc.), BC/NAV will automatically apply these outbound transactions to inbound entries, usually on a FIFO basis (unless applied to a specific inbound entry).Ā The Application Worksheet can be used to help correct applications if done improperly.Ā Therefore, the remaining quantity for outbound entries is usually zero, while the remaining quantity for inbounds entries will have a balance until the quantity on that line is fully applied to outbound entries.Ā Hope this helps.
David Wiser
Sr. Solution Consultant
Tigunia
2019-2020 Board of Advisors
BCUG|NAVUG All-Star
DSC Communities replied 5 years, 2 months ago 1 Member · 0 Replies -
The discussion ‘Remaining Quantity – Item Ledger Entry’ is closed to new replies.
