Released Production Order-change status to Finished error
Posted by DSC Communities on January 17, 2017 at 2:05 pm-
Richard Goward
MemberJanuary 17, 2017 at 2:05 PM
We are trying to change status to Finished for a Released Production Order.
We are receiving this message in a dialog box.
The status of order 101120 cannot be changed as it is related to planning line 1090000 in worksheet FOR. LABOR DEFAULT.Any ideas?
Richard Goward
Dermae
Are you running Manufacturing > Planning > Planning Worksheets? It sound like a line on that worksheet is related to the production order you are trying to close.
NAVUG Programming Commitee
NAVUG Membership Committee
Richard Goward
MemberJanuary 18, 2017 at 1:14 PM
Lewis:
We do not show anything on the planning worksheet related to this released prod order.——————————
Richard Goward
Dermae
Richard Goward
MemberJanuary 18, 2017 at 1:17 PM
Another post on another site with the same error referred to an extra entry in the routing of the rel prod order.
We do not have an extra routing line for this order.——————————
Richard Goward
Dermae
What type of worksheet is your “For. Labor Default” batch? Is that an output journal? Do you use reservations on components? A bit more detail would help us track this down.
Ben Baxter
Consultant
Accent Software, Inc.
Carmel IN
Check the Subcontracting Worksheet > DEFAULT batch.
Loren Raber
IT Technician
SUPERB Industries Inc
Sugarcreek OH
There’s definitely something on some worksheet somewhere.
Alex Apodaca
MemberJanuary 20, 2017 at 10:40 AM
Hello Richard,Go to the Planning Worksheet and you can see if you can specifically find line 1090000 and delete that line. If not then if you delete all the lines on the Planning Worksheet it should clear your error, but you may need to consider if someone is using it before you do. They could then re-populate the Planning Worksheet lines afterward. You might even be able to export all the lines to Excel and paste them back in… not sure about that for a quick answer, but clearing this form particularly that specific line should clear your error. Make sure you match up the correct For Labor and Default specifications..
If my response has helped you please mark the answer.A Apodaca
Sr. Consultant
CA United States
Richard Goward
MemberJanuary 20, 2017 at 2:40 PM
Hi All:
The issue was with the subcontractor worksheet.
It has been cleared up.
Thanks for all the help.——————————
Richard Goward
Dermae
DSC Communities replied 8 years, 7 months ago 1 Member · 0 Replies -
The discussion ‘Released Production Order-change status to Finished error’ is closed to new replies.
