Reading a DateFormula field using Microsoft SQL Server
  • Reading a DateFormula field using Microsoft SQL Server
    Posted by DSC Communities on January 10, 2017 at 4:49 pm
    • Aydan Golaszewski
      January 10, 2017 at 4:49 PM
      I have a question coming from one of our developers who is trying to read NAV Item Data from a SQL Database.
      Does anyone know of a way to read Navision DateFormula fields using Microsoft SQL Server. I have a value of ‘30D’ (or “1W+1D)”  which I can see in the NAV client, but SQL Server returns a value of ‘30’.
      We were advised to look at this post from Peter Wijntjes from 2007, has anyone implemented something like this? Your insights are much appreciated.
      if you want to be able to read the date formula from SQL this might be of use:
      select [Due Date Calculation] ,
      cast ([Due Date Calculation]as varbinary) as Binary,
      description from [testcompany$Payment Terms]
      I have created a number of test entries in de Payment Terms table and the resultset is like this:
      Due Date Calculation    Binary            Description
      3                       0x3304                          3W
      3                       0x3305                          3M
      3                       0x3307                          3Y
      3+1                   0x33072B3102               3Y+1D
      +14+2                0x01052B3134022B3203     CM+14D+2WD
      so, appearently all numerical values are stored as there Char representative ( ‘3’ –> 0x33, ‘1’ –> 0x31 )
      the ‘+’ sign as well
      and the special (language independent elements) are coded:
      C = 0x01 *current
      D = 0x03
      W = 0x04
      M = 0x05
      Y = 0x07
      (and the WD is translated to D) in this example.
      Aydan Golaszewski
      Lead ERP Analyst
      Jason Pharmaceuticals (Medifast)
      Owings Mills MD
    • Loren Raber
      January 11, 2017 at 8:11 AM
      A SQL scalar-valued function seems to work:
      CREATE FUNCTION [dbo].[FormatDateFormula]
       @DateFormula varchar(32)
      RETURNS varchar(50)
      AS
      BEGIN
       SET @DateFormula = REPLACE(@DateFormula,CHAR(1),’C’)
       SET @DateFormula = REPLACE(@DateFormula,CHAR(2),’D’)
       SET @DateFormula = REPLACE(@DateFormula,CHAR(3),’WD’)
       SET @DateFormula = REPLACE(@DateFormula,CHAR(4),’W’)
       SET @DateFormula = REPLACE(@DateFormula,CHAR(5),’M’)
       SET @DateFormula = REPLACE(@DateFormula,CHAR(6),’Q’)
       SET @DateFormula = REPLACE(@DateFormula,CHAR(7),’Y’)
       RETURN @DateFormula
      END
      Loren Raber
      IT Technician
      SUPERB Industries Inc
      Sugarcreek OH
    • Aydan Golaszewski
      January 11, 2017 at 9:47 AM
      Loren thank you so much – that is a gem you provided!  Thanks to Dynamics User Group.
      Aydan Golaszewski
      Lead ERP Analyst
      Owings Mills MD
The discussion ‘Reading a DateFormula field using Microsoft SQL Server’ is closed to new replies.
