Production Journal Error Message
  • Production Journal Error Message
    Posted by Unknown Member on October 6, 2022 at 9:59 am
    • Becca Moss
      October 6, 2022 at 9:59 AM
      When attempting to post lines in the production journal for a released production order, this error pops up:
      “Document No. must be equal to ‘PJRNL000001’ in Item Journal Line: Journal Template Name=PROD. ORDE, Journal Batch Name=USER_6573F, Line No.=10000. Current value is ‘RPPO-000009’.”
      This happens regardless of user or production order. The only difference will be the Journal Batch Name in the error, as it will update to the user attempting to post.
      Has anyone seen this error?Ā
      Becca Moss
      Turnkey Technologies, Inc
      St. Charles
    • Devraj Ghosh
      October 7, 2022 at 12:49 AM
      Did you by any chance assign a no. series for the batch name USER_6573F? You can check this by going to Item Journal templates and then checking batches listed under PROD. ORDE. Check to see if No. Series is filled in.
      DEVRAJ GHOSH
      PRINCIPAL
      O 469.262.1747
      M 916.425.2233
      https://www.ternpoint.solutions/
    • David Wiser
      October 7, 2022 at 6:37 PM
      Open the item journal template and then open the batch referenced in the error.Ā  Check to see if a No. Series code is assigned.Ā  If so, you can remove it, or note the number series, go to the No. Series table and make sure that “Manual Nos.” is checked as Yes.Ā  That should allow it to post.
      David Wiser
      Sr. Solution Consultant
      Dynamics Northwest LLC
      BCUG|NAVUG Board of Advisors
      BCUG|NAVUG Programming Committee
      BCUG|NAVUG All-Star
    Unknown Member replied 3 years, 5 months ago 1 Member · 0 Replies
The discussion ‘Production Journal Error Message’ is closed to new replies.
