Problem deleting a Purchase Invoice In NAV 2017
Posted by DSC Communities on September 14, 2017 at 2:42 pm-
Georges Leduc
MemberSeptember 14, 2017 at 2:42 PM
Hello NAVUG,
The company I work for have just went live on NAV 2017 and they have a strange behaviour when they try to delete a Purchase Invoice in their live company.
When they do, they get that message: You do not have the following permissions on TableData Purch. Inv. Header: Insert
It’s strange because all the users have SUPER has permission in the Security, therefore they have access to everything.
The other strange part is that in a test company which is on the same DB, same SQL server, etc… they do not have that problem.
Has anyone of you encounter that behaviour before? If so, what was the solution?
I looked on Customer Source if there was anything about that and could not find something similar.
Thanks in advance for your help.
Georges Leduc
Georges Leduc ERP Consultant, S.A.
L’Ile Perrot QC
Just a shot inĀ the dark:Ā Tray recompiling the Purch. Inv. HeaderĀ table (Table 122).
NAVUG Programming Committee
NAVUG Membership Committee
Sophia Gjorgievska
MemberSeptember 15, 2017 at 9:19 AM
We had the same issue when we went live with a client on 2017. Ā What version of Codeunit 364 (PostPurch-Delete) are you running? Ā One of our developers found a bug with this codeunit and after we replaced it we were no longer having the issue. Ā The version we’re running is dated 2/23/17, but I’m sure it should be fixed in subsequent versions.——————————
Sophia Gjorgievska
Senior Consultant
Socius
Brecksville OH
Georges Leduc
MemberSeptember 20, 2017 at 9:41 AM
Hi Sophia,Your suggestion is the solution.Ā I installed a more recent codeunit 364 and it fixed the problem.
Many thanks for your help.
Georges Leduc
L’Ile Perrot QC
Val Gameiro
MemberSeptember 15, 2017 at 9:38 AM
in NAV you cannot delete posted documents. It’s against the GAAP, and it affects a lot of tables, including the G/L — and you can’t delete stuff off the G/L.You have to Credit Memo it out. Use the Copy Document function which should automatically apply the purchase credit memo to the invoice.
V
Val Gameiro
Senior NAV Analyst
BPL Plasma
Austin, Texas
Sophia Gjorgievska
MemberSeptember 15, 2017 at 10:26 AM
Val,I don’t think Georges is talking about deleting a posted document, which I agree should never be deleted. This is a bug in 2017 where a Purchase Invoice, which hasn’t Ā been posted yet, Ā cannot be deleted.
Sophia Gjorgievska
Senior Consultant
Socius
Brecksville OH
Georges Leduc
MemberSeptember 18, 2017 at 7:36 AM
Thank you all for your reply,Sophia, I will take a look at that codeunit.
Lewis, I will compile that table.
Val, Sophia is right I am looking to delete a non posted document, however, for your information, you can delete a posted document. Ā What you cannot delete is all the ledgers that have been generated by the document.
Thanks again
Georges
Georges Leduc
L’Ile Perrot QC
Sue Barrett
MemberSeptember 18, 2017 at 2:31 PM
We experienced an issue that prevented unposted purchase invoices from being deleted in NAV 2017.The issue turned out to be a new “feature” with 2017 whereby the deletion of purchase invoices was not permitted if the posted invoice number series is set to the same no series.
Our NAV partner fixed this for us and was checking if this was fixed in CU2.
ES Barrett
NAV Project Manager
Sudbury
Sophia Gjorgievska
MemberSeptember 19, 2017 at 9:38 AM
In our case, we don’t ever have the same No. Series assigned to 2 different document types. Ā Replacing just the codeunit with a newer version resolved the issue.——————————
Sophia Gjorgievska
Senior Consultant
Socius
Brecksville OH
Sophia Gjorgievska
MemberSeptember 21, 2017 at 3:27 AM
That’s great, Georges. Thanks for the update.——————————
Sophia Gjorgievska
Senior Consultant
Socius
Brecksville OH
DSC Communities replied 7 years, 11 months ago 1 Member · 0 Replies -
The discussion ‘Problem deleting a Purchase Invoice In NAV 2017’ is closed to new replies.
