Printing RequestFilterFields on Report Header
  • Printing RequestFilterFields on Report Header
    Posted by Steve Simon on May 18, 2020 at 8:21 pm
    • Steve Simon
      May 18, 2020 at 8:21 PM
      #Technical #BC/NAVPlus
      Dear Developers,
      I created a BC report of Items sold for each customer. A Request Page allows the BC user to select a document date range from a filter field. How do I pass that active RequestFilterField to the header of the report, so that the report recipient will know the date range or other filter for this report?
      Copy of report page attached.
      Steve Simon
      Steve Simon
      Pres.
      PDG Consultants, Inc.
      Clearwater
    • Kyle Hardin
      May 19, 2020 at 7:44 AM
      It depends. If the request page field is a simple variable, you can pass that into the report dataset as it is.
      If you have addedĀ RequestFilterFields to the data item Sales Invoice Header (or whatever your main Go Get Me Stats data item is), then you can put that into your dataset with GETFILTER or GETFILTERS. I have attached the BC15 report called Sales History. In the data item Item, look at the field called ItemFilter. That’s how it goes into the RDLC data set. Then look farther down in the code in OnPreReport, and you can see that ItemFilter is getting set to Item.GetFilters, which (after the Request Page has done its part) creates a text string of all of the filters the user set on the Item Record with the request page.
      Kyle Hardin
      NAV Developer
      ArcherPoint Inc.
      Duluth GA
    • Steve Simon
      May 20, 2020 at 4:18 PM
      Kyle,
      Thanks so much for the expert reply.
      I am trying to understand how to use the GetFilter method against the Request Filter fields to capture whatever filters have been set if any for this report. So I’ll review the code attachment and see how to integrate it into my report.
      Thanks again.
      Steve Simon
      Steve Simon
      Pres.
      Clearwater
    • Steve Simon
      May 21, 2020 at 12:23 AM
      Kyle,
      I copied the relevant lines of the code snippet you sent – into my existing report. It worked (sending the Request Filter to the Report Header and today’s date to the Report Footer.) Picture attached.It’s so simple when you know.
      Thank you very much..
      Sincerely,
      Steve Simon
      Steve Simon
      Pres.
      Clearwater
    Steve Simon replied 6 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Printing RequestFilterFields on Report Header’ is closed to new replies.
