Powershell: Get job queue log entries – ALL companies
  • Powershell: Get job queue log entries – ALL companies
    Posted by DSC Communities on December 21, 2018 at 4:00 am
    • Henrik Jensen
      December 21, 2018 at 4:00 AM
      Does anybody do this….
      I have 50 companies, and I need to get daily status of the “Update currency Exchange rates” has status “Succes” or not.
      Can this be done with powershell ?
      Henrik Jensen
      IT Chief
      Ocean Prawns A/S
    • Saurav Dhyani
      December 21, 2018 at 3:02 PM
      I doubt that it can be done via PowerShell but if you are using NAV 2017 or higher you can use task scheduler to achieve similar results.
      You can create a task via code in NAV/BC and then you can decide the output method in code. It can be an e-mail, a file or any other way you can think of.
      How to use task scheduler –Ā https://docs.microsoft.com/en-us/dynamics-nav/task-scheduler
      Saurav Dhyani
      ArcherPoint Inc.
      Duluth
      Blog – https://saurav-nav.blogspot.com
    • Henrik Jensen
      December 27, 2018 at 2:42 AM
      Thanks.
      I build a report, that get status from all companies, the last 7 days.
      /Henrik
      Henrik Jensen
      IT Chief
      Ocean Prawns A/S
    • Mathew Ealy
      December 28, 2018 at 8:10 AM
      You could do this with powershell if you call sql from shell. Then feed the data to a simple html page to show green or red per company. I could see something like that being useful to manage 50 companies status for a number of different statuses.
      Mathew Ealy
      Nav Support Specialist
      Rentokil N. America
      Reading PA
    DSC Communities replied 6 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Powershell: Get job queue log entries – ALL companies’ is closed to new replies.
