PO Receiving
PO Receiving
Posted by DSC Communities on February 27, 2018 at 3:48 pm-
Kurt Bebeau
MemberFebruary 27, 2018 at 3:48 PM
I tried to receive a quantity the was slightly more than the PO Line quantity and I received a system message stating that my entered quantity exceeded what was available to be received.Ā Is there a system setting that can be entered to allow an acceptable overage on receiving?——————————
Kurt Bebeau
HLT, Inc.
?For standard out of the box NAV, you’ ll have re-open the PO and increase the order quantity or add a new line for the extra quantity to receive.
NAVUG Programming Committee
NAVUG Membership Committee
Jenn Claridge
MemberFebruary 28, 2018 at 7:58 AM
?Lewis is right.We add a bit of code to most customers so that if they Qty. to Receive is greater than the Quantity column it automatically updatesĀ to allow for itĀ but it is not out of the box.
Jenn Morton
Manufacturing Consultant
Sabre Limited
Cambridge Ontario Canada
Kurt Bebeau
MemberFebruary 28, 2018 at 9:27 AM
Thanks for your feedback.Ā So the only way to handle for ‘Over-Receipt’ is a customization?Ā I would imagine this holds true for G/L lines as well?Most systems I’ve worked with allow for over-receipt and handle the overage as variance within either Supplier and/or Item approved percentages.
Thanks again,
Kurt——————————
Kurt Bebeau
HLT, Inc.
Eduardo Diaz
MemberMarch 1, 2018 at 9:24 AM
Hi Kurt,
Over receiving can be a double edged sword. Some companies like it, some don’t. Current NAV doesn’t have this feature which I think should be included as a setup option. However, customization is simple and the process to add additional quantities is also very simple. This is the strength of NAV. Hope this helps you make the best decision for your organization.
Cheers,
Eduardo Diaz
IT Director
Minequip Corp.
Miami FL
Hi Kurt,
As Lewis mentioned, to achieve this without any customization, you will need to open the PO, increase the quantity or add additional line to receive the additional quantity. If needed, you can do a small customization of adding a field “original Quantity” to keep track of what the original quantity was so you can manage how many times you are over receiving or under receiving.
Best,
Meenakshi?——————————
Meenakshi Singh
Home Market Foods, Inc.
Norwood MA
Aaron Brown
MemberMarch 7, 2018 at 3:21 PM
From what I can tell, it’s a common customization.Ā Many add-on packages include it as a feature.Ā BC-ERP is one that includes it.Ā They’ve added a Delivery Tolerance Catalog that allows you to set over / under tolerances and specify different ones for specific customers and vendors.Ā Ā——————————
Aaron Brown
Director of Finance
Oregon Ice Cream
Camas WA
DSC Communities replied 8 years, 1 month ago 1 Member · 0 Replies -
The discussion ‘PO Receiving’ is closed to new replies.
