Planning Worksheet Error
  • Planning Worksheet Error
    Posted by DSC Communities on June 17, 2019 at 10:22 am
    • Adam Aponte
      June 17, 2019 at 10:22 AM
      Good morning,
      When running the planning worksheet this morning, we ran into this error “The Prod. Order Component does not exist. Identification fields and values: Status=’3′,Prod. Order No.=’16560′,Prod. Order Line No.=’10000′,Line No.=’130000′”.
      It’s referencing a component of a finished production order because the planning worksheet is trying to reschedule that finished production order. Anyone have any ideas as to why the planning worksheet is trying to reschedule a finished production order? I’ve confirmed that the production order is not in the released production order list but is truly in the finished production order list and all items have already been consumed.Ā
      Thank you.Ā
      Adam Aponte
      NAV Support Tech
      Zefon International
      Ocala FL
    • Jason Nicolaou
      June 18, 2019 at 7:35 AM
      This is an interesting one.Ā  Have you created some custom statuses for items and or production orders?Ā  The portion of the error that says Status = “3” stands out to me.Ā  Somehow NAV’s logic is triggering that suggestion.Ā  Is there any way that you can trace that logic backwards?Ā  It almost sounds like that status is interrupting the logic enough to allow NAV to see finished production orders.Ā  Similar to that warning when you under-consume on a production order and NAV warns that not all of the consumption has been recorded.Ā  I realize this answer isn’t great.Ā  Hopefully it provides a little perspective and / or direction.
      Jason Nicolaou
      Engagement Manager
      Sikich, LLP
    • Andrew Good
      June 18, 2019 at 8:09 AM
      ?In base NAV “Production Order”.Status = 3, is a Released Production Order. Please check if you have any customizations around production orders including Change Status.
      Production Order Status values
      0= Simulated,
      1=Planned,
      2=Firm Planned,
      3=Released,
      4=Finished
      Andrew Good
      President
      Liberty Grove Software
      Oakbrook Terrace IL
    • Adam Aponte
      June 20, 2019 at 2:41 PM
      Hi Jason and Andrew,
      I have confirmed that we do not have any customization’s in our system regarding Production Order Status’s. I also confirmed that everything was correctly consumed on those production orders.Ā
      What I did notice is that originally when I posted this question, there were three items on the Planning Error Log. Now there’s only one. The other two disappeared on their own. I will send this off to our developer to see if they can explain this glitch a little more. Thank you for your input.
      Adam Aponte
      NAV Support Tech
      Zefon International
      Ocala FL
    • Alfredo Zelaya
      June 25, 2019 at 10:38 AM
      As Andrew mentioned above with the statuses, have you finished the Production Order in question and changed the status to “Finished”?
      Alfredo Zelaya
      Megadyne Americas LLC
      Fairfield NJ
    DSC Communities replied 6 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Planning Worksheet Error’ is closed to new replies.
