Nav2018 upgrade to BC – Links to files coming across
  • Steven Chinsky MVP
    Moderator
    March 23, 2023 at 1:46 pm
    @firefighter – I have not but a thought that you could puh the links to SharePoint and then connect the records. You might consider asking eFOCUS who works heavily in SharePoint and linking data.
    Steve
    • Jackie Whittington
      March 23, 2023 at 2:11 pm
      Thanks Steven. Currently the files reside on a local File Server. I have halted porting the files up to Sharepoint as I understand that is even more complex.
  • Saurav Dhyani (MVP)
    March 23, 2023 at 2:21 pm
    It’s possible. We have done it for all our upgrade projects.
    In Summary steps are –
    1. Copy and upload all your files to a online file sharing services like – SharePoint (as steven mentioned), OneDrive, AWS, Azure file Share, Azure blob storage.
    2. Update data in Record Link with local URL to the target files. [A script is possible to update all record links]
    3. For New Links, that will be created after the upgrade – you can either have a AppSource app / Per Tenant Extensions to upload file to your selected online file storage solution.
    API Integration with business central, make it possible to integrate external systems.
The discussion ‘Nav2018 upgrade to BC – Links to files coming across’ is closed to new replies.
