NAV Tables
  • Posted by Pam Bird on June 9, 2017 at 11:36 am
    • Pam Bird
      June 9, 2017 at 11:36 AM
      How do I add a NAV table to the EDI NAV Tables (Lanham)?
      Pam Bird
      System Administrator
      Clean Control
      Warner Robins GA
    • Stephen Marsh
      June 12, 2017 at 9:00 AM
      Hi Pam,
      There is a report (Load E.D.I Navision Fields) that needs to be run to update the Lanham product. It will create a text file that then needs to to be imported. I do believe you need a developer license for this.
      Stephen Marsh
      Enterprise Services Manager
      Axxess Logistics
      Vaughan, Ontario
      Canada
    • Meenakshi Singh
      June 12, 2017 at 9:44 AM
      Hi Pam,
      You will ned to run the load E.D.I. NAV fields report to addĀ NAV tables and fields to Lanham tables.
      However, it creates/updates the E.D.I. text file that you need to import to update the E.D.I. codeunit so it will requireĀ developer license or work with your NAV partner.
      Meenakshi
      Meenakshi Singh
      Home Market Foods, Inc.
      Norwood MA
    • Dave Cintron
      June 12, 2017 at 1:15 PM
      Pam,
      It matters whether you are adding a table to the outgoing or incoming fields, and the NAV and Lanham version you are on. Not every table and field is automatically mapped and the codeunit that loads the fields changes in later versions of Lanham. You really should get your partner’s advice on this.
      Dave Cintron
      Dynamics West
      Ventura CA
    Pam Bird replied 8 years, 4 months ago 1 Member · 0 Replies
The discussion ‘NAV Tables’ is closed to new replies.
