NAV Reports print to wrong page size
Posted by Lewis Rosenberg on May 19, 2017 at 11:51 am-
Hello All,
I have a user running theĀ NAV2013r2 client on a new Windows 10 install.Ā EverythingĀ report sent toĀ a printerĀ prints at the wrong page size.Ā All ofĀ the printer settings look to be correct (printer preferences are set to Letter size pages).Ā Ā Is there anything else I can look at?Ā NAV seems to be the only application with a printing issue.
NAVUG Programming Committee
NAVUG Membership Committee
Alex Wiley
MemberMay 19, 2017 at 1:37 PM
Is this happening for all users?——————————
Alex WileyHaschen
Denver CO
Just one user.Ā I just uninstalled and reinstalled the NAV client, but that did not change anything.
Kris Ruyeras
MemberMay 19, 2017 at 3:45 PM
Is this on a shared printer through GPO or print server? If so, depending on the setup, local settings will get overwritten from the server level if they are not allowed to make changes to the printer settings.——————————
Kristoffer Ruyeras
Seattle, WA
She is printing to both a shared network printer and a local printer with the same issue on both.Ā I tested with the network printer and I was able to change printer preferences.Ā My changes held, but did not make a difference.
Lewis,
It’s not the old A4 ISSUE rearing it’s ugly head?
Michael Carr
VP , Finance
Philadelphia Scientific LLC
Montgomeryville PA
It could be.Ā
What experience did you have, Michael?——————————
This was ancient but apparently in the build we went live with on in 2015 with NAV2013 R2 all the stock reports were set up to print on A4 letter stock.Ā Since there were no printers with A4 paper in it they would just not print.
This was version 7.1.36703.0. A fix was released andĀ prior to NAV 2015 and Microsoft provided it to us as a standalone program. If you are up to date it shouldn’t be a problem but one never knows………It could be report parameters………
Michael Carr
VP , Finance
Montgomeryville PA
Cynthia Priebe
MemberMay 19, 2017 at 5:59 PM
My understanding is that unless the page sizeĀ is coded into the NAV report, it will use the paper size defined for as theĀ default printer device. ĀThe first thing I would check is the advance printing preferences for paper size on her default printer.Ā
If this is not the issue, not sure what it might be. This is the “A4 thing” I am aware of!
Cynthia Priebe, MCTS, DCP
Liberty Grove Software
Grafton OH
Geovanny Fuentes
MemberMay 22, 2017 at 11:26 AM
Let’s diagnose this:
1. Remote Connection or Local.
2. Did you rename the “PersonalizationStore” file. So a new file is created.3. Did the user reboot the computer?
4. Did you confirm the corrects date/file/size Printer driver was installed. Maybe it was updated.
5. Did you delete the printer, reboot, install the network printer again.
6. Did you log in as another use on the same computer and print to see if it’s a local issue or specific to the user id?
7. Is there issues with other reports or just this specific one? Did you verify it’s the same Report Object Id#?Good luck.
Geovanny Fuentes
San Diego CA
Patrick Hulst
MemberMay 23, 2017 at 7:11 AM
We have had the same “issue” with the paper size coming from the default printer. Ā Depending on user / store setup the last printer installed was a Zebra label printer – with the default paper size of 4″ x 1″. Ā Makes a mess of the reports printed to a laser printer.Check your user default printer in Windows. Ā Also if you’re using a run-as to authenticate NAV the current logged in Windows user may not be the profile NAV is using to determine the printer configuration. Ā (We have many users authenticating to NAV on a shared PC.)
Patrick Hulst
Retail Applications Projects Manager
Home Hardware Stores Limited
St Jacobs ON
Greg Partlow
MemberMay 24, 2017 at 8:40 AM
Ive had this happen.
check in your display settings right click desktop -> display settings. if it is anything besides 100% it will print weird sizes. this is confirmed with Microsoft as well. if you print to pdf does the print out look normal? there’s no fix for this currently. sent it through Microsoft. it calls up winforms with no parameters to pass to the winforms which unfortunately doesn’t take in to account the display settings size. it renders the print out this waythis is from my email correspondance from them.
DPI font scaling drivers influence GDI+ low level libraries behavior.
GDI+ libraries are referenced by SSRS (SQL Server Reporting Service) Report Viewer .NET assembly and drive report rendering.
Report Viewer .NET assembly is docked into a NAV WinForm (NAV Page).
This is a Windows 10 platform setup that can affect SSRS Report Viewer with Dynamics NAV.
This applies to all the custom developed and Microsoft Standard products that use SSRS RV within this context (NAV, AX, CRM) such as the one below:
http://community.dynamics.com/ax/f/33/p/186811/468761
Via Control PanelAppearance and PersonalizationDisplay select “set a custom scaling level”, DPI font scaling can be modified, where and if needed.
The article below describes how to adjust these settings:
http://www.tenforums.com/tutorials/5990-dpi-scaling-level-displays-change-windows-10-a.htmlif the ‘side of text apps and other items is
Greg Partlow——————————
Thanks for all of the suggestions everyone.
Greg:Ā I tried changing the display settings from 150% to 100% and then back to 150% and printing is working correctly now.Ā I’ll try again tomorrow to see if this holds.
Greg Partlow
MemberMay 30, 2017 at 1:10 PM
Lewis,
has it continued to print correctly with the 100% scaling setting?——————————
Greg Partlow
Sentinel Technology Group
Harrisburg PA
Still good after a three-day weekend.Ā Thanks, Greg!
Iliana Diaz de Leon
MemberFebruary 13, 2019 at 1:21 PM
HiĀ
in your response-solution you mentioned:Ā I tried changing the display settings from 150% to 100% and then back to 150% and printing is working correctly now.ĀWhere are the display settings? Could you please advise?, IĀ“m facing similar issue.
Regards
ilianadlb
?I believe that I just right-clicked on an empty part ofĀ the Windows desktop and clickedĀ display settings.
BCUG/NAVUG All-Star
BCUG/NAVUG Programming CommitteeNAVUG/BCUG FOCUS Houston March 13-14, 2019
Twitter: @RosenbergL
LinkedIn: https://www.linkedin.com/in/rosenbergl/
Lewis Rosenberg replied 8 years, 3 months ago 1 Member · 0 Replies -
The discussion ‘NAV Reports print to wrong page size’ is closed to new replies.
