NAV 4.0 Block Obsolete items Question
  • NAV 4.0 Block Obsolete items Question
    Posted by DSC Communities on June 2, 2017 at 12:36 pm
    • Marc Heick
      June 2, 2017 at 12:36 PM
      We are having issues with users selecting obsolete items when creating orders. Ā We are considering using the Blocked CheckBox on the Item page. Ā Are there any concerns to be aware of by using the Blocked check Box on the Item?Ā
      Thank You,
      Marc
      Marc Heick
      RPI Industries
      Medford NJ
    • Ian Ray
      June 2, 2017 at 1:35 PM
      Blocked does not create any problems I am aware of for items. You can still use warehouse functions, you just won’t be able to purchase/sell the items. If these are truly obsolete items, it is a good idea. I also tend to remove valid posting groups and add obvious, leading numbers indicating the item is not a regular inventory item (i.e. 99999) in the event that someone accidentally unchecks “blocked.”
      Ian Ray
      Cypress Grove
      Arcata CA
    • David Wiser
      June 2, 2017 at 2:10 PM
      This is one of the areas that I wish NAV would fix. Ā Both customers and vendors have levels of ‘blockage’ designed to prevent certain usage. Ā But not with items. Ā At a minimum, NAV should have a block level which prevents inbound transactions like purchases, but allows outbound transactions. Ā This would allow user to sell off existing inventory but prevent purchasing new inventory.
      Dave Wiser
      Beckwith & Kuffel
      Seattle WA
    • Ian Ray
      June 2, 2017 at 3:19 PM
      Agreed, David. I also would like a setting to allow sales quotes for blocked customers.
      Ian Ray
      Cypress Grove
      Arcata CA
    • Marc Heick
      June 2, 2017 at 4:27 PM
      Ian,
      Thank you for the information. It is appreciated!!
      Cheers,
      Marc
      Marc Heick
      RPI Industries
      Medford NJ
The discussion ‘NAV 4.0 Block Obsolete items Question’ is closed to new replies.
