NAV 2018 closes when minimized
Posted by Meenakshi Singh on January 23, 2019 at 1:58 pm-
We recently upgraded to NAV 2018 (October 2018). It was working fine…but recently whenever we minimize theĀ NAV window, it just puts NAV into the non-responding mode and then eventually just closes it. It only happens when we minimize theĀ window. if we leave it open and open another program and then go back to it, it works fine and does force exit NAV.Ā
NAV 2018 on windows 10 environment. Doesn’t seem to be windows updates related. Anyone else experiencingĀ such an issue? Any suggestions?
Meenakshi
Meenakshi Singh
Home Market Foods, Inc.
Norwood MA
I think it might be either related to a corrupted personalization that may be causing this issue.
If you have some specific users who are facing it, please test with –Ā
1. Navigate to Role Center.
2. Using Menu, select Customize and then select Reset-User-SpecificĀ settings.
3. Reset all setting.
4. Close and re-open client and see if it still occurs.——————————
Saurav Dhyani
ArcherPoint Inc.
Duluth
Blog – https://saurav-nav.blogspot.com
Thanks, Saurav!! That is a good point but the users that have experienced it don’t have any user specific personlization.. we try to add most of the personalizationĀ in configuration mode as those are more department specific than user specific. but will give that a try next time it happens.
One way we have been gettingĀ around for now is – either uninstall or re-install of NAV or in some cases just deleting and re-creating the configurationĀ file.
Meenakshi——————————
Meenakshi Singh
Norwood MA
Franz Kalchmair
MemberFebruary 17, 2019 at 5:19 PM
try using different resoutions on your screen (less dpi).——————————
Franz Kalchmair
Microsoft MVP
Senior Consultant
Austria, Europe
Same results… we have tried it with different resolutions with Citrix, without CitrixĀ etc… so far, the only solution that works is reinstallingĀ or updating theĀ configuration file.
Meenakshi Singh
Norwood MA
I have experienced something similar on NAV 2017 in a Windows 10 environment. What fixed it for me was turning off the “Fix apps that are blurry” option in settings. Search for “blurry” or go to Settings -> Display -> Advanced scaling settings and toggle off “Let Windows try to fix apps so they’re not blurry”. Windows will sometimes pop up a prompt asking you to turn this setting on and it is as easy as clicking apply.
Jonathan Kleist
IT Manager / NAV Admin
Gustavo Preston
Chelmsford, MA
I will give that a try next time it happens. Thanks, Jonathan!!
Meenakshi Singh
Norwood MA
Meenakshi Singh replied 7 years, 1 month ago 1 Member · 0 Replies -
The discussion ‘NAV 2018 closes when minimized’ is closed to new replies.
