Our auditors are requesting a listing of all manual journal entries for the prior year in Excel. Is there a way to run this in NAV2009?
Thank you!
—————————— Wendy Harden Italvibras USA Princeton IL ——————————
Cynthia Priebe
February 3, 2017 at 9:18 AM
Wendy,
NAV is great in this area.
1. Go to Trail Codes, Financial Management, Setup, Source Code Setup to find out what Source Code is posted on the General Ledger Entries for the type of posting (i.e. General Journal, IC General Journal, Reversal, etc.) 2. Make sure the column “Source Code” is showing on the G/L Register List and General Ledger Entries. 3. You can then filter using the source codes defined in step 1. 4. You may also find the User ID column on the General Ledger Entries to be helpful.
This should provide what is needed.
—————————— Cynthia Priebe, MCTS, DCP Senior Business Analyst and Project Manager Liberty Grove Software Grafton OH —————————— ——————————————-
Cynthia Priebe
February 3, 2017 at 9:31 AM
Correction – .”1. Go to Trail Codes, Financial Management, Setup, Source Codes to find out what Source Code is posted..”
Sorry, had to edit my post – responded from memory, but then checked…..should know better than to do that š
Wendy Hodge
February 3, 2017 at 9:50 AM
Thank you!! I was using the ledger entries and filters but just wasn’t getting there. Source Code was key! Thanks so much!
—————————— Wendy Harden Italvibras USA Princeton IL —————————— ——————————————-
Cynthia Priebe
February 3, 2017 at 9:51 AM
Happy to help!
