LS Retail
  • Posted by Kim Dallefeld, MVP on February 28, 2018 at 1:53 pm
    • Kim Dallefeld
      February 28, 2018 at 1:53 PM
      I am trying to help and NAV-LS Retail end-user and LS Retail is not my specialty. We are looking for documentation or someone who can help with how-to information for setting up Allocation or as known in the retail world, setting up a Distro.
      Any assistance is appreciated.
      Kim Dallefeld
      VP Professional Services
      Syte Consulting Group
      kdallefeld@sytecg.com
      Past NAVUG Board Chairman
      NAVUG Programming Committee
    • Patrick Hulst
      March 1, 2018 at 6:30 AM
      The customer and partner portal is here:
      https://portal.lsretail.com/
      Most documentation exists there.  Depending on what version a feature may not have changed so you will need to go back a version or 3 to find it.  LS is built on NAV and isn’t much different than other ISV solutions – if this isn’t a retail specific issue then you’re probably looking back to base NAV for the answer.  How that impacts the store may be a different discussion.  EG: if you’re using special orders it uses base sales orders with reservations.  If you’re using the purchasing module you have options on worksheets or PO’s, then what sourcing rules you’re using (from central warehouse, other locations, suppliers, etc).
      There are some good North American partners available as well.  I would contact the USA office to get some specific guidance.   They may be able to direct you to a partner with the specific knowledge you’re looking for.
      Contact LS Retail experts
      Patrick Hulst
      Retail Applications Projects Manager
      Home Hardware Stores Limited
      St Jacobs ON
    • Franz Kalchmair
      March 1, 2018 at 2:57 PM
      for lsretail portal you need to have an account.
      best you start with online help: http://help.lsnav.lsretail.com/Content/home.html
      quite good, is like msdn.
      Franz Kalchmair
      Microsoft MVP
      Senior Consultant
      Vienna, Austria, Europe
    • Patrick Hulst
      March 2, 2018 at 6:38 AM
      Franz you’re correct – but if this is a customer up to date with EP they can register for an account for free.  This also gives them access to the user forums specific to LS customers.
      Patrick Hulst
      St Jacobs ON
    Kim Dallefeld, MVP replied 6 years, 9 months ago 1 Member · 0 Replies
The discussion ‘LS Retail’ is closed to new replies.
