Loading Assembly BOM’s from NAV->B.C.. Best Approach?
  • Loading Assembly BOM’s from NAV->B.C.. Best Approach?
    Posted by DSC Communities on June 29, 2020 at 8:26 am
    • dave cameron
      June 29, 2020 at 8:26 AM
      We are in process of moving from NAV to B.C..Ā  Legacy data for Items has been migrated along with other master data.Ā  What is the best approach for loading the related assembly BOM’s?
      David Cameron
      Microsoft Financial Consultant
      Templer Group
      ANCASTER ON
    • Ben Baxter
      June 29, 2020 at 9:34 AM
      Depending on your version of NAV, you could use a Rapid Start Package.Ā  The tables will be very similar, so it might be as easy as just importing and applying the package.
      If you are on an older version of NAV, you may need to export the data to Excel via SQL or XML port, then build a Config Package to bring the data into Business Central.
      Ben Baxter
      Consultant
      Accent Software, Inc.
      carmel IN
    DSC Communities replied 5 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Loading Assembly BOM’s from NAV->B.C.. Best Approach?’ is closed to new replies.
