Last line of generated report pdf is being split across two pages
  • Last line of generated report pdf is being split across two pages
    Posted by Eric-Parrott on October 4, 2017 at 2:59 pm
    • Eric Parrott
      October 4, 2017 at 2:59 PM
      Does anyone know of a solution to this problem?Ā  This only happens on reports of certain length.Ā  I’ve tried changing the page margins of the rdlc layout, and have moved the text box that is being split up a bit farther on the page layout (which fixes the problem on one report), but the problem still occurs on other generated reports the tend to end right on a page break.
      last line of report is getting split across two pages
      Any suggestions would be appreciated.
      Eric Parrott
      Red River Computer Company
      Claremont NH
    • Eric Parrott
      October 5, 2017 at 8:33 AM
      In case anyone else comes across this issue, I believe I found the solution.Ā  The text box did not have the ‘Keep Together’ property set to true in the rdlc layout, which defines whether to keep all sections of the data region grouped together on on page.Ā  Once you set it to true the line that fell near the page break will get pushed to the next page if it does not completely fit on the first page.
      Eric Parrott
      Claremont NH
    Eric-Parrott replied 7 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Last line of generated report pdf is being split across two pages’ is closed to new replies.
