Lanham EDI850 mapping challenge (items with qty=0 and wrong UOM)
  • Lanham EDI850 mapping challenge (items with qty=0 and wrong UOM)
    Posted by Lewis Rosenberg on March 1, 2024 at 4:34 pm
    We have a customer that is sending items with a zero quantity on EDI orders (850s) and a unit of measure of EA. This is an invalid Unit of Measure for these items and the customer says they cannot omit the zero qty items from the orders.
    My first thought was to use the “Bypass Segment if Blank” logic if the quantity is zero, but that does not work because the element value is “0” and not an empty/blank value.
    The only other option I can come up with is to set up an EA to CS conversion, but I’m not feeling very comfortable doing that because it can create other issues.
    Is there anything else that I am missing?
    Lewis Rosenberg replied 1 year, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Meenakshi Singh
    March 3, 2024 at 9:45 am
    Any Lanham experts in the group that can help navigate this? @marylanham
    • Mary Lanham
      March 4, 2024 at 10:03 am
      Thanks, Meenakshi! I’ll ask Charlotte to answer that one.
      Mary
  • Charlotte Kinney
    March 4, 2024 at 12:35 pm
    Good morning Lewis!
    I am assuming these are non-SDQ orders. I ran a test and in my mapping I have the Trigger set on my PO1-07. The quantity comes in on the PO1-02. I setup a conditional on the PO1-07 that says if the PO1-02 = 0, then NO Trigger. If PO1-02 <> 0, then map to the Sales Line “Item Cross Ref” with Trigger = TRUE. See screenshot. Test this out and let us know how it works out for you!
    • Meenakshi Singh
      March 4, 2024 at 11:08 pm
      Thanks, Charlotte for your response. šŸ™‚
    March 5, 2024 at 9:16 am
    Thank you Charlotte.
    That worked great when I requeued the file on the server (but not when I tried to reprocess the EDI RECEIVE document).
  • Charlotte Kinney
    March 5, 2024 at 9:35 am
    Excellent! Glad that worked out for you. Yes, you would have to re-drop the file (and not “Process Receive Docs”) since a mapping change was made as the original file was based on the mapping prior to this change. I hope that makes sense!
    March 5, 2024 at 9:43 am
    Yes it does. Thanks again!
The discussion ‘Lanham EDI850 mapping challenge (items with qty=0 and wrong UOM)’ is closed to new replies.
