Lanham EDI XML
    July 7, 2023 at 10:04 am
    Hello Noreen,
    I don’t believe that I fully iunderstand what you are trying to do.
    If you are sending EDI in XML format, you can set the Interface File Type to XML on your EDI Template on the File Format tab. You can use different EDI Templates for different EDI Documents for the same EDI partner, if necessary.
    On the General tab of the card page for your EDI Document, you can assign the EDI Template Code.
  • Noreen Fujita-Sacco
    July 7, 2023 at 11:57 am
    Hi, Lewis.
    Thanks for your response. Your example is how I set up a test XML yesterday when I was checking out this functionality. I hope below clarifies.
    Where I am stuck is setup of the document before I get to mapping. For example, I could use a generic document for the import. However, there is no corresponding document type for a label. The options available are attached. In these options it is not possible to create a new code.
    Where the screenshot shows Navision Document, there is also no generic document I could use for the export to request the label. I’d have to repurpose an existing code for the request as well.
    Is NAV/Lanham limited to these types of documents or can I pick any and repurpose it for my needs?
    July 7, 2023 at 11:58 am
    The Navision Document List in that new screenshot is the same list I sent yesterday.
    July 7, 2023 at 2:26 pm
    Interesting, I never noticed the Document Type field before. I have that field empty for all documents for all of my EDI trading partners.
    What EDI document number (ie. 850, 810, 856,..) are you trying to set up?
    July 7, 2023 at 8:07 pm
    Fascinating the many different ways a thing can be accomplished in NAV.
    I have never heard of a numeric document number for a shipping label. To be clear, this is not the GS1-128. In the testing info online the request is SLR and label is SL.
The discussion ‘Lanham EDI XML’ is closed to new replies.
