Lanham EDI 180
  • Posted by DSC Communities on November 14, 2017 at 2:30 pm
    • Brianne DiLorenzo
      November 14, 2017 at 2:30 PM
      Hello all,
      We have a request from a Trading Partner to implement EDI 180 inbound and outbound.Ā  The only purpose of the document is to receive Return Authorization.Ā  There is nothing this document needs to do inside of NAV.
      We have the option to do this via webforms with our VAN, but that isn’t preferred.
      Has anyone successfully implemented this?
      Brianne DiLorenzo
      Business AnalystĀ
      Clean Control Corporation
      Brianne DiLorenzo
      Business Analyst/Purchasing Assistant
      Clean Control
      Warner Robins GA
      November 14, 2017 at 4:26 PM
      ?I have not implemented an EDI 180, but I have mapped other inbound #EDI documents such as the 864 and 816 that do nothing in NAV using Lanham’s EDI.Ā  It is just a matter of creating the map and then you can look at the data received or print the detailed data received.?
      NAVUG Programming Committee
      NAVUG Membership Committee
    • Michelle Berry
      November 15, 2017 at 7:59 AM
      This sounds like an EDI log recognition request only. As Lewis stated,Ā “It is just a matter of creating the map and then you can look at the data received or print the detailed data received.” You can do this with Lanham or even Anveo EDI (which uses no VAN and can leverage ‘shared’ directories and will process internally (100% integrated to Dynamics NAV)).?
      Michelle Berry
      Anveo GmbH
      Hamburg
    • Brianne DiLorenzo
      November 16, 2017 at 7:18 AM
      Thank you all for your input.
      From what I understand of the TP’s request (which isn’t much at this point), they are sending us a 180 and would like an RGA number in return to confirm authorization, hence the 180 inbound and outbound.Ā
      I guess I may have misspoke when I said “do nothing in NAV”.Ā  I see in my version of Lanham the Export 180 document, but not the inbound 180 document.Ā  Using version SE0.60.05.
      Brianne DiLorenzo
      Business Analyst
      Clean Control
      Warner Robins GA
The discussion ‘Lanham EDI 180’ is closed to new replies.
