Job times within Job Queue changed after Daylight Savings Time
  • Job times within Job Queue changed after Daylight Savings Time
    Posted by DSC Communities on November 7, 2017 at 10:18 am
    • Barbara Pipia
      November 7, 2017 at 10:18 AM
      I have (14) jobs that their Start time changed an hour earlier once Daylight Savings changed.Ā  A few other jobs did not change.Ā  Is there a setting I should be aware of?
      Is this normal?
      Barbara Pipia
      IT Director, Infrastructure
      Citizen Watch Company of America
      New York NY
    • Cynthia Priebe
      November 7, 2017 at 10:55 AM
      Barbara,
      Possibly it is the “Date & time” setup on the machine running the job queue?
      Date & time can be defined to adjust for daylight saving time automatically.Ā
      I would check there first.
      Cynthia Priebe, MCTS, DCP
      Liberty Grove Software
      Grafton OH
    • Barbara Pipia
      November 7, 2017 at 2:30 PM
      Thanks Cynthia.Ā  I’ll check.Ā  The only thing is that not all jobs were changed.
      Barbara Pipia
      IT Director, Operations
      New York NY
    • Cynthia Priebe
      November 7, 2017 at 2:36 PM
      If I understand how the Job Queue runs, how the jobs are setup to run dictates what machine is considered “local” for the purpose of Date and time. You may have more than one server instance each running on its own machine, or the job is kicked off by a user from their local machine.Ā
      Again, not sure, but somewhere to look. Let me know if this proves to be the source of the difference.
      Grafton OH
    • Jason Wilder
      November 8, 2017 at 8:01 AM
      As far as our environment goes this is normal and I do not know of a way to automatically fix this without some programming (not worth the effort for us).Ā
      Every time Daylight Savings Time happens I go into Job Queue entries and filter on “No. of Minutes between Runs” > 60 (anything an hour or under won’t be affected).Ā  I then go in and manually adjust the “Earliest Start Date/Time” to be correct.Ā  Don’t forget sometimes you have to change the date as well as the time if something went from 12:00 AM to 11:00 PM for example.
      Jason Wilder
      Senior Application Developer
      Stonewall Kitchen
      York ME
    • Ron Ketterling
      November 8, 2017 at 8:00 AM
      Check each NAV service to see if they are all set for UTC or server time. UTC is best if you have multiple time zones-NAV will translate to local time. Some apps will require server time to properly manage time tracking.
      Sent from my Verizon, Samsung Galaxy smartphone
      ——Original Message——
      Is this normal?
      Barbara Pipia
      New York NY
The discussion ‘Job times within Job Queue changed after Daylight Savings Time’ is closed to new replies.
