Inventory valuation by bin?
  • Inventory valuation by bin?
    Posted by DSC Communities on March 16, 2018 at 10:16 am
    • Traci Albosta
      March 16, 2018 at 10:16 AM
      We are using NAV 2017.Ā  Is there a report in NAV that will give me inventory valuation by bin?Ā  Or tables with the information (bin, item, quantity, valuation) that I can pull the information into JET Express?Ā  Thanks for any suggestions you can offer.
      Traci Albosta
      Comitt Well Solutions LLC
      Katy TX
    • Franz Kalchmair
      March 18, 2018 at 3:15 PM
      you could add a flowfield in table bin content using table value entry.
      Franz Kalchmair
      Microsoft MVP
      Senior Consultant
      Vienna, Austria, Europe
    • David Wiser
      March 19, 2018 at 12:25 AM
      Just be aware that you would need to calculate the cost for the specific bin since no costing data resides at the bin level, its all at the location level.Ā  So, if you have quantity in two bins within a location, you would need to allocate the location cost to the bins based on the quantity in that bin compared to the total location quantity.Ā  That is, unless I’m missing bin costing somewhere.
      Dave Wiser
      Beckwith & Kuffel
      Seattle WA
    • Naveen Jain
      March 19, 2018 at 2:32 PM
      If you are maintaining inventory by lot or Serial Number, then can write custom reports to calculate the inventory values of those lots/serials in the bin, but as a standard NAV you do not have any report which can give you valuation by Bin.Ā
      Otherwise you can calculate the value of the item by location, and based on the bin content inventory you can calculate the valuation.
      Naveen Jain
      Director of IT
      Symbex Companies
      Santa Fe Springs CA
    • Traci Albosta
      March 20, 2018 at 3:26 PM
      Thank you very much for all of your input!Ā  I was hoping there was an easy report someplace, but I guess not.
      Traci Albosta
      Katy TX
    • Aaron Brown
      March 21, 2018 at 10:08 AM
      Are you using standard costs?Ā  If so, you could query the bin contents by item and multiply the quantity on hand by the standard per the item table.Ā  This may or may not tie to the GL, depending on where you’re at in your inventory reconciliation cycle, but it should get you to the theoretical cost by bin.
      Aaron Brown
      Director of Finance
      Oregon Ice Cream
      Camas WA
    DSC Communities replied 7 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Inventory valuation by bin?’ is closed to new replies.
