Inventory mess for an item
  • Inventory mess for an item
    Posted by Lewis Rosenberg on August 2, 2017 at 11:06 am
      August 2, 2017 at 11:06 AM
      How do you fix inventory when the total qty for an item in the open Item Ledger Entries balances with the Warehouse Entries, but the Warehouse Entries have three lots (with inventory) that don’t exist in the Item Ledger Entries….Ā  Also, another lot has a completely different warehouse location in the item ledger entries than the warehouse entries?
      So to simplify that statement:
      I have three lots for an item, we’ll call them Lot A, B, and C.
      The inventory in lots A,B, and C have open (on hand) inventory amounts in the Item Ledger Entries that equal the inventory in lot Z in the warehouse entries.
      Lot Z does not have any inventory according to the Item Ledger Entries.
      Also – Lot H is in the QA warehouse in the Item Ledger Entries but the Warehouse Entries show it in Whse FG.
      When I run Calculate Whse Adjustments in the Item Journal, I do not get anything.
      NAV2013r2
      Base UOM=EA
      FG Whse is directed putaway and pick, putaway UOM=CS (Item has 6ea per cs)
      QA whse just has bin control
      It must be Monday…I don’t believe what the calendar says.
      NAVUG Programming Committee
      NAVUG Membership Committee
    • Jason Wilder
      August 3, 2017 at 7:48 AM
      Can you use the Item Reclass Journal or the Whse. Rclqss Journal to fix this?
      Jason Wilder
      Senior Application Developer
      Stonewall Kitchen
      York ME
    • Crystal Tollison
      August 3, 2017 at 8:24 AM
      ?I’m with Jason, use the Reclass Journals.
      Crystal Tollison
      Consultant
      ArcherPoint Inc.
      Lawrenceville GA
    • Eric Moe
      August 3, 2017 at 10:35 AM
      I would do a Warehouse Journal adjustment to zero all inventory of the item, then do the corresponding Item Journal adjustment. Ā Then, add the item back in to the proper bins with the Warehouse Journal and do the Item Journal again, being sure the costs match on steps 2 & 4. Ā
      You will break the cost tracking, but it should clean up the inventory/location entries.
      Eric Moe
      Global Supply Chain Manager
      Industrial Revolution
      Tukwila WA
      August 3, 2017 at 2:07 PM
      ?Thanks for the imput!
      We had our partner help with this.Ā  Standard NAV functionality would not work because the lot numbers did not match up between whse entries and item ledger entries.Ā  As for the item that was in the QA location in the ILE and FG in whse entries, that fixed itself.Ā  (Someone was probably in the middle of a transaction when I was looking at it).
    Lewis Rosenberg replied 8 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Inventory mess for an item’ is closed to new replies.
