Inactivating GL Accounts & Departments
  • Inactivating GL Accounts & Departments
    Posted by DSC Communities on October 19, 2017 at 3:33 pm
    • Dean Long
      October 19, 2017 at 3:33 PM
      We’re preparing to eliminate accounts and consolidate departments in the next facial year.Ā  I was hoping someone could point me in the right direction on how to inactivate these accounts/departments (NAV 2016).
      Dean Long
      Perdido Beach Resort
    • Ian Ray
      October 19, 2017 at 4:44 PM
      Accounts and dimension values can be “blocked” with the blocked field.
      Accounts not used in the current fiscal year can be deleted. But, this will also delete the reference in related ledger entries, so you will end up with blank account values.
      Entire dimensions can’t be deleted, ever; you are stuck with those.
      Ian Ray
      Cypress Grove
      Arcata CA
    • Bob Cole
      October 20, 2017 at 7:11 AM
      ?The Merge Utility from Dynamics NAV Addons allows users to move all of the leger entries from one G/L Account, Customer, Vendor, or Dimension into another and delete the source account.
      Bob Cole
      Managing Director
      DynamicsNAVAddons
      Longwood FL
    • Mark Keener
      October 20, 2017 at 9:14 AM
      Bob – don’t you also have some sort of “Dimension Manager” tool available?Ā  Would that allow him to “merge” dimensions as well?Ā  That way he could delete the unused ones after they were merged.
      Mark Keener
      CV, LLC
      Centerville OH
    • Bob Cole
      October 24, 2017 at 12:07 PM
      ?Mark,
      The Dimension Manager tool allows users to add, modify, or delete any Dimension value associated with any posted record(s).Ā  So, yes, a user could use Dimension Manager to replace an unwanted value with a more desirable value but it would be for a definedĀ list of records (Customer Ledger Entries, Vendor Ledger Entries, G/L Ledger EntriesĀ for example) but we’ve never configured it to globally change all entries for one dimension to another.Ā  Which is not to say it couldn’t be done.Ā  ButĀ that mightĀ not allow a user to delete a Dimension no longer associated with any entries.Ā  Although since we’ve never done it, I haven’t tested it.
      The Merge Utility would definitely allow a user to merge all records from one DimensionĀ into another and delete the source Dimension.
      Bob Cole
      Managing Director
      DynamicsNAVAddons
      Longwood FL
    • Val Gameiro
      October 23, 2017 at 8:58 AM
      ?As far as I know, G/L accounts can’t be deleted while they have G/L entries under them. The NAVAddons tool makes sense, but I don’t think NAV will let you delete accounts otherwise.
      What I’ve done presently and in past companies, is add a filter to te relevant Pages to leave out blocked items. Out of sight, out of mind. I do that for Items, G/L Accounts, Dimension values, etc.
      I am proposing a re-implementation at my current company to leave out garbage data as much as possible.
      Val Gameiro
      Senior NAV Analyst
      BPL Plasma
      Austin, Texas
    • Alistair Betts
      October 20, 2017 at 9:34 AM
      We undertook a complete Chart of Accounts & Dimension revamp as part of our NAV2016 re-implementation (coming from NAV2009).Ā
      We’re using the NAV multi-company Consolidation functions and Jet reporting. We’ve build cross-reference tables to map old-codes to new-codes so we can report historical data from our NAV2009 database against new data from NAV2016.
      Not sure if you are going to this extend, but if you are, please reach out to me for more details.
      Cheers,
      Alistair Betts
      Senior Business Analyst
      Gogo, LLC.
      Chicago IL
    • Cynthia Priebe
      October 24, 2017 at 11:00 AM
      There are differences between versions, but the following is for NAV 2016 (from MSDN):
      https://msdn.microsoft.com/en-us/library/hh168958(v=nav.90).aspx
      Before a G/L account can be deleted, the following criteria must be met:
      The balance on the account must be zero.
      If there is a date in theĀ Allow G/L Acc. Deletion BeforeĀ field in theĀ General Ledger SetupĀ window, the account must not have ledger entries on or after that date.
      If there is a check mark in theĀ Check G/L Account UsageĀ field in theĀ General Ledger SetupĀ window, then the account must not be used in any of the following setup tables:
      Currency
      Customer Posting Group
      Vendor Posting Group
      Job Posting Group
      General Posting Setup
      Bank Account Posting Group
      VAT Posting Setup
      FA Posting Group
      Inventory Posting Setup
      Service Contract Account Group
      Gen. Journal Template
      Gen. Journal Batch
      Gen. Jnl. Allocation
      FA Allocation
      Cynthia Priebe, MCTS, DCP
      Liberty Grove Software
      Oakbrook Terrace IL
    • Cynthia Priebe
      October 24, 2017 at 11:10 AM
      I should also add that if the accounts to be deleted are used in Comparative Statements, you will need to wait until they are no longer needed for this reporting. And it is also important to note, the GL Entries are not deleted. However, the GL Entries will NOT have GL Account No. in the record for the deleted accounts.
      Deleting GL Accounts should be done with caution and all parties aware of the outcome. I have customers that have deleted accounts after no use over 5 years. Until then, they block the accounts and remove them from account schedules. It is good to see them on the Trial Balance in the event someone got around all the checks and balances and posted to the accounts in error.
      Good luck!
      Oakbrook Terrace IL
The discussion ‘Inactivating GL Accounts & Departments’ is closed to new replies.
