Import Users in Bulk
Posted by DSC Communities on June 11, 2018 at 3:31 pm-
Valarie Wiles
MemberJune 11, 2018 at 3:31 PM
Does anyone have a powershell command to import bulk users into NAV without the need to manually create new users one by one?——————————
Valarie Wiles
Goodwill Southeast Georgia
Savannah GA
Franz Kalchmair
MemberJune 11, 2018 at 3:54 PM
the ps command isĀ new-navserveruser.Ā
https://docs.microsoft.com/en-us/powershell/module/microsoft.dynamics.nav.management/new-navserveruser?view=dynamicsnav-ps-2018
https://community.dynamics.com/nav/b/magnosblog/archive/2015/08/26/creating-users-with-powershellps script for bulk import.Ā
https://marcellusnav.wordpress.com/2017/07/31/import-nav-users-from-csv-with-powershell/——————————
Franz Kalchmair
Microsoft MVP
Senior Consultant
Austria, Europe
Valarie Wiles
MemberJune 11, 2018 at 4:52 PM
Thanks. I found that article, too. I’ll follow the steps and see how itĀ goes!——————————
Valarie Wiles
Savannah GA
Franz Kalchmair
MemberJune 12, 2018 at 12:54 PM
according to your message. i did the following:* i starte the windows powershell ISE in admin mode. this is needed, because only then your are allowed to create new users in nav
* then created a csv text file with comma as separator. semicolon does not work here. saved it as c:tempusers.csv. check, if these windows users are created on your server (AD).
UserName,FullName,Email
domainuser1,John,john@test.com
domainuser2,Adam,adam@test.com* created a new text file and copied the script into the text file, saved it as c:tempImport-NavUsersFromCSV.ps1
* in the ps ISE i wrote then “cd temp” to change to my working directory.
*Ā Import-Module .Import-NavUsersFromCSV.ps1
to load the new script*Ā $Permissions = (‘SUPER’)
to set the default user permissionset for the new users* at last:
Import-NavUsersFromCSV -NavVersion 100 `
-NavServerInstanceName ‘DynamicsNAV100’ `
-AuthenticationMethod Windows `
-ImportFilePath ‘C:Tempusers.csv’ `
-PermissionSets $Permissionsresult:
Creating domainuser1
Verbose: Opening admin connection to ServerInstance ‘MicrosoftDynamicsNavServer$DynamicsNAV100’
Verbose: Admin connection to ServerInstance ‘MicrosoftDynamicsNavServer$DynamicsNAV100’ has been opened
Verbose: Ausführen des Vorgangs “New-NAVServerUser” für das Ziel “ServerInstance = MicrosoftDynamicsNavServer$DynamicsNAV100, Sid = S-1-5-21-236
3956306-4252412874-2321867446-1054, WindowsAccount = domainuser1″.
Verbose: Closing admin connection to ServerInstance ‘MicrosoftDynamicsNavServer$DynamicsNAV100’
Verbose: Admin connection to ServerInstance ‘MicrosoftDynamicsNavServer$DynamicsNAV100’ has been closed
Verbose: Ausführen des Vorgangs “New-NAVServerUserPermissionSet” für das Ziel “ServerInstance = MicrosoftDynamicsNavServer$DynamicsNAV100, Permi
ssionSetId = SUPER, Sid = S-1-5-21-2363956306-4252412874-2321867446-1054, WindowsAccount = domainuser1″.
Creating domainuser2
3956306-4252412874-2321867446-1055, WindowsAccount = domainuser2″.
ssionSetId = SUPER, Sid = S-1-5-21-2363956306-4252412874-2321867446-1055, WindowsAccount = domainuser2″.
Verbose: Admin connection to ServerInstance ‘MicrosoftDynamicsNavServer$DynamicsNAV100’ has been closedthe “change password at next login” flag is not set. this is only set if you use theĀ -ChangePasswordAtNextLogOn option with theĀ New-NAVServerUser command.
Franz Kalchmair
Microsoft MVP
Senior Consultant
Austria, Europe
Mathew Ealy
MemberJune 13, 2018 at 7:15 AM
The script needs edited to map to your nav powershell modules.Ā
MEaly58/Nav_Powershell#CSV format <#! FullName,Login,Email,Profile, You can find the user profiles in your system on table “User Personalization (2000000073)” #> #Import the NavAdmin Module Import-Module “C:Program FilesMicrosoft Dynamics NAV90ServiceNAVAdminTool.ps1″ #Nav version changes the 90 to a differnt number #Import the CSV file **Change the -path to the file $Users = Import-CSV –path “\serversharefile.csv” #Variables $InstanceName = “NavInstance” #Execute script foreach ($User in $Users) { $FullName = $User.‘FullName’ $Login = $User.‘Login’ $Email = $User.‘Email’ $Profile = $User.‘Profile’ New-NavServerUser –ServerInstance $InstanceName –WindowsAccount $Login –FullName “$FullName“ –ProfileID “$Profile“ } ——————————
Mathew Ealy
Nav Support Specialist
Rentokil N. America
Reading PA
DSC Communities replied 7 years, 2 months ago 1 Member · 0 Replies -
The discussion ‘Import Users in Bulk’ is closed to new replies.
