Import from a Data File
  • Import from a Data File
    Posted by DSC Communities on July 18, 2019 at 8:00 am
    • Ranjith E S
      July 18, 2019 at 8:00 AM
      Hi All,
      Thanks in advance to guide me on below case,
      I have a NAV backup file as .navdata andĀ  trying to import this navdata file using Import from a Data File feature. The back up file were created from NAV 2016 version and currently I am trying to import into the same version of NAV. From the Import Data card,Ā  I have selected the backup file,the Tennant ID is default, in the import section I have selected the Application Data check box and the company also selected.Finally I have click on the OK button system throws an error as ” The data was exported from a different version of Microsoft Dynamics NAV”.Ā
      I couldn’t to trace out the issue for this error. According to my records the NAV version is same.Ā
      Does anyone ever faced this issue? How this can be resolved?
      Looking forward to get help from here!
      Best Regards,Ā
      #FunctionalĀ #Import from data file #Navdata
      Ranjith E S
      Functional Consultant
      Nest Information Technologies
    • Justin Falconer
      July 18, 2019 at 11:27 AM
      When Importing NAV Backup Files it has to be the same NAV Release, and all Objects in the database has to be the Same.Ā  If one object is changed then the import will not work.
      Justin Falconer
      Tender Corporation
      Littleton NH
    • Suresh Kulla
      July 18, 2019 at 12:45 PM
      Check the Build Version. They may be different.
      Suresh Kulla
      NAV Technical Architect
      Atlanta GA
    • Ranjith E S
      July 19, 2019 at 12:22 AM
      thanks Justin and Suresh for your time.
      I have checked the build version and it is same.Ā
      Ranjith E S
      SFO
    • Suresh Kulla
      July 19, 2019 at 10:12 AM
      Ranjith,
      I did run into a similar issue before but the error message was different. In my case, I had the extensions published/Installed in one database but not in the other.
      Suresh Kulla
      Atlanta GA
    DSC Communities replied 6 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Import from a Data File’ is closed to new replies.
