We are heading towards implementing SOX which requires an audit trail for any changes made to NAV objects (mainly Tables) in production environment. It has to be preferably a log that cannot be modified by anyone, especially by the developer who import objects in NAV. Is there a log or report available within SQL that can provide such information?
I found several forums talking aboutĀ logging DDL changes using EVENTDATA() function. If no other option is available, I will use that unless someone can provide a better solution. Any help or direction towards a solution will be greatly appreciated. Thank you!
—————————— Zahera (Jolly) Keshwji Lead Business Analyst and NAV Programmer BioLegend San Diego CA ——————————
Suresh Kulla
September 4, 2018 at 1:24 PM
Zahera,
You cannot track this from inside NAV but can add a trigger on the SQL side on the Object Table to track the changes. Please check out this blog. ..::candyworm .com | sweeties::..
—————————— Thanks Suresh Kulla NAV Technical Architect Atlanta GA —————————— ——————————————-
