how do i find what sales order # an assembly order is linked to?
Posted by Unknown Member on September 20, 2017 at 8:11 am-
morning guys, wondering if I can find what sales order # a given assembly order is linked to. Ā does anyone know?
G.——————————
Guy Lacey
Director of Operations
Salon Services & Supplies, Inc.
Renton WA
Project Management
Paul Simpson
MemberSeptember 21, 2017 at 4:19 AM
They should be linked via Reservation EntriesIn NAV the Reservation Entries page should show you both Reserved For and Reserved From columns because the page accumulates the information for you.Ā If you mean within your own reports though you will need to search Reservation Entries table (337) for both applicable records.
There’ll be one entry with Source Type 900, Source ID = your Assembly Order Number, Positive = Yes.
Find that then find the other Reservation Entry with the same Entry No but Positive = No and its Source ID should be your Sales Order No and Source Ref. No. would be the line on the Sales order (usually counting 10000 at a time so 50000 would be the 5th line on your Sales Order unless lines had been deleted or new lines had been inserted at some point).——————————
Paul Simpson
Business Analyst
Vado
Cheddar
Peter Koch
MemberSeptember 22, 2017 at 12:42 PM
Guy,I don’t know how much technical information you want but I had a similar requirement (linking a Production Order to a Sales Order Line). The SQL query I used is listed below. I never found a cleaner approach (though I stopped looking once I landed here). I found out the hard way that the Top 1 filter is required to handle a specific case.
select
[Source ID]
from dbo.[XXXXX$Reservation Entry]
where [Entry No_] = (select top 1 [Entry No_] from dbo.[XXXXX$Reservation Entry] where [Source ID] = Ā [Document No_] and [Source Ref_ No_] = [Line No_])Ā and [Source Type] = ‘5406’ )
as ‘W/O No.’——————————
Peter Koch
General Manager
CGW Camel Grinding Wheels
Buena Park CA
Annette van der Muur
MemberSeptember 21, 2017 at 6:18 AM
?Hi,
T904- Assemble-to-Order Link
shows you the link between the Assembly Order (ATO) and the Sales Order Line number.When you print the assembly order R902, it will show the Sales Order also.
Hal Leonard
The Netherlands
Jason Luchka
MemberSeptember 21, 2017 at 8:03 AM
?Table 904 – Assemble-to-Order Link maintains this.I can’t recall if it was a mod or out of the box, but we have an action on our Assembly Order named “View Sales Order” and if there is a sales order linked to that Asm Order (via table 904), we launch that order’s page. Also, on the sales lines, line button, there is an action to viewĀ any relatedĀ asm. order. In this way, we can get to the other side from either end.
Jason Luchka
Programmer / Analyst
FFR Merchandising, Inc.
Twinsburg OH
Paul Simpson
MemberSeptember 22, 2017 at 3:33 AM
TIL: I’ve been doing it the hard way.Ā Thanks Annette and Jason.Ā I’m so annoyed I missed that.——————————
Paul Simpson
Business Analyst
Vado
Cheddar
Unknown Member replied 8 years, 6 months ago 1 Member · 0 Replies -
The discussion ‘how do i find what sales order # an assembly order is linked to?’ is closed to new replies.
