Error when running Import-DeltasToNavContainer
  • Error when running Import-DeltasToNavContainer
    Posted by Eric-Parrott on September 18, 2020 at 3:28 pm
    • Eric Parrott
      September 18, 2020 at 3:28 PM
      Hi All,
      I am trying to setup a docker environment for our NAV 2017 Development using the CSIDE IDE.
      I was able to successfully spin up a container using the correct standard NAV 2017 image, however when I attempt to import our NAV customizations to the container using the Import-DeltasToNavContainer powershell command, the process fails during the import stage on certain objects. It first failed on the VAT Entry table object with the following error “You do not have permission to insert into the VAT Entry table”, so I removed the table from the delta files and ran it again. The second time it failed to import the Salesperson/Purchaser table with error “your program license does not allow you to create the X field in the Salesperson/Purchaser table”.Ā  We have the Application-Developer license granule.Ā  Does anyone know if we need to have the Solution-Developer granule in order to run the Import-DeltasToNavContainer command in order to run the process successfully?
      What I thought was interesting is that I can modify both those objects inside of our developer environment, but when I attempt to run the Delta process, it errors out. I’ve checked and confirmed that the correct license is applied to the container I am attempting to pull the deltas into.
      Thanks for any suggestions!
      ~Eric
      #Technical??
      #NAV2017
      Eric Parrott
      Red River
      Claremont NH
    Eric-Parrott replied 4 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Error when running Import-DeltasToNavContainer’ is closed to new replies.
