Error – Unable to View PO Details
    February 18, 2025 at 10:24 pm
    The error is stating that you do not have READ access to table 6217 – Sustainability Setup.
    I am not familiar with this table and it does not exist on my BC14 system, so it is either relatively new, or from an add-on or enhancement.
    In either case, the fix is to add a READ permission for that table to a permission set assigned to anyone who will be processing purchase orders.
  • Jeff Woodard
    February 19, 2025 at 8:39 am
    Down Accepted answer
    This table is in the BC Sustainability extension (https://learn.microsoft.com/en-us/dynamics365/business-central/finance-manage-sustainability). If your business doesn’t monitor and record it’s environmental impact, you can also uninstall the extension. In our case, that was simpler than adding and maintaining the security settings. Be aware, however, if you make extensive use of configuration packages that it will remove some columns in key tables that may require you to rebuild some configuration packages. As always test in a sandbox environment first.
